Smcm75(at)aol.com Guest
Posted: Sun Apr 12, 2009 4:29 am Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
In a message dated 4/11/2009 11:04:24 PM Eastern Daylight Time, gareywittich2000(at)yahoo.com writes:
Quote: | Is there an equivalent to this product ??? What did you use ???
Thanks, Garey
Use B-2 or better known as Proseal to stick an >016 small patch on the backside of the hole then fair over the outside with whatever you want. wont come off crack etc.
Feeling the pinch at the grocery store? Make dinner for $10 or less.
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
Posted: Sun Apr 12, 2009 5:13 am Post subject: Fill MK319BS Rivet Head holes to seal out moisture |
Also B-2 can be used to fill rivet heads since it sets -up like hards rubber and can be painted with no problem. Be warned it is not cheap and it is the messiest junk that you will ever have to work with. It is used for aircraft fuel tank sealant as primary purpose have plenty of MEK to clean up with
