First real result of the NTSB report
jmaynard
PostPosted: Wed Apr 15, 2009 3:48 pm    Post subject: First real result of the NTSB report Reply with quote
Well, the first real result of the NTSB report has happened: the DPE I was
going to take my CFI-SP checkride with tomorrow postponed it until the issue
is resolved. We talked about it for a while, and I explained what I knew
about the issue; she said she'd think about it some more and let me know.
I've spent six months getting ready for the checkride. Now, I have no idea
when, or if, I'll be able to get it done. There's only one other DPE who
does CFI-SP checkrides in the region, and no FAA inspector does them. I have
no idea where else I could go within reasonable flying distance of KFRM.
I understand and respect her decision. I'm not going to ask anyone to get in
my airplane who's not completely comfortable with the choice.
I've got lots of words to use for the situation. None of them are usable on
this forum.
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
psm(at)att.net
PostPosted: Wed Apr 15, 2009 6:39 pm    Post subject: First real result of the NTSB report Reply with quote
Hi Jay,
I feel your pain.
I wonder if your thinking is a bit clouded on this whole issue. Do
you need your plane to do the check ride you are prepared
for? Perhaps there is another plane you can use to show your
proficiency. I understand you have been preparing for using your own
plane, but I suspect a rental would work too. It might require you
spend a little time practicing with another plane, and it might
require a trip to a location where an appropriate plane is
available. Both of those costs seem relatively small to me. (But
what do I know?)
Paul
this forum.
jmaynard
PostPosted: Wed Apr 15, 2009 7:12 pm    Post subject: First real result of the NTSB report Reply with quote
On Wed, Apr 15, 2009 at 07:39:41PM -0700, Paul Mulwitz wrote:
I wonder if your thinking is a bit clouded on this whole issue. Do you
need your plane to do the check ride you are prepared for? Perhaps there
is another plane you can use to show your proficiency. I understand you
have been preparing for using your own plane, but I suspect a rental would
work too. It might require you spend a little time practicing with another
plane, and it might require a trip to a location where an appropriate plane
is available. Both of those costs seem relatively small to me. (But what
do I know?)
I'm planning to start with my local FSDO and see if there's another examiner
I can try. When I set up this checkride, there was only the one (and the
Minneapolis FSDO doesn't even do CFI-SP checkrides); since then, one
inspector mentioned another, but the DPE herself told me that he wasn't a
CFI examiner. I'll get the real story tomorrow.
The big problem I've got is that I live 120 miles from the closest place
that rents LSAs. I'd also have to spend 5 hours in one just to get signed
off (insurance requirements), and also to get my flying in whichever one up
to CFI standards. That's not going to be something I can commute to easily,
so it'll take travel and hotel expenses, on top of the rental costs.
Another big problem is that my schedule is about to get quite full with
travel for work and vacations I've already paid for. It won't free up again
until mid-June at the earliest. I'd have to work transition training and
another checkride around all that. Getting the checkride scheduled is
problematical enough as it is.
Yes, I'm still highly pissed off by the situation, especially since it was
just a matter of a couple of days between the report and the checkride.
Jay Maynard, K5ZC
JAPhillipsGA(at)aol.com
PostPosted: Wed Apr 15, 2009 7:50 pm    Post subject: First real result of the NTSB report Reply with quote
man, you got to learn to live with some disappointment.
In a message dated 4/15/2009 11:13:02 P.M. Eastern Daylight Time, jmaynard(at)conmicro.com writes:
--> Zenith-List message posted by: Jay Maynard <jmaynard(at)conmicro.com>
work too.� It might require you spend a little time practicing with another
is available. Both of those costs seem relatively small to me.� (But what
do I know?)
AMD Zodiac CH601XLi N55ZC ================================================ the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; � ===================================================
Great deals on Dell’s most popular laptops – Starting at $479
hansriet
PostPosted: Wed Apr 15, 2009 9:00 pm    Post subject: Re: First real result of the NTSB report Reply with quote
Jay,
Can't you just use ANY plane to do the check ride? Doesn't need to be LSA.
hansriet
PostPosted: Wed Apr 15, 2009 9:41 pm    Post subject: Re: First real result of the NTSB report Reply with quote
Guilty.
jmaynard
PostPosted: Thu Apr 16, 2009 2:23 am    Post subject: First real result of the NTSB report Reply with quote
On Wed, Apr 15, 2009 at 10:41:32PM -0700, hansriet wrote:
Guilty.
Wow...someone eve more famous, and deservedly so, than me...
Jay Maynard, K5ZC
jmaynard
PostPosted: Thu Apr 16, 2009 3:09 am    Post subject: First real result of the NTSB report Reply with quote
I believe the CFI-SP checkride needs to be done in an LSA. Even if it
didn't, there's another problem for me: I'm operating without a medical
under the sport pilot rule, so I need to use an LSA (since the examiner
won't be pilot in command during the test, and someone has to).
Jay Maynard, K5ZC
hills(at)sunflower.com
PostPosted: Thu Apr 16, 2009 4:54 am    Post subject: First real result of the NTSB report Reply with quote
Ya, I had to do my sport pilot check ride in an Ercoupe, as it was LSA legal
and the Cessna 152 was not.
Roger
hansriet
PostPosted: Thu Apr 16, 2009 5:42 am    Post subject: Re: First real result of the NTSB report Reply with quote
So are you saying that the CFI-SP doesn't need to have a CPL (with a second class medical)?
Gig Giacona
PostPosted: Thu Apr 16, 2009 5:48 am    Post subject: Re: First real result of the NTSB report Reply with quote
Of course they don't. For that matter a CFI doesn't have to have a medical to give instruction.
W.R. "Gig" Giacona
601XL Under Construction
hansriet
PostPosted: Thu Apr 16, 2009 6:56 am    Post subject: Re: First real result of the NTSB report Reply with quote
[quote="jmaynard"]On Wed, Apr 15, 2009 at 10:41:32PM -0700, hansriet wrote:
[quote] Guilty.
[/quote]
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml[/quote]
That's all relative Jay. I own a T-Shirt that reads, "I'm Big In Europe" and that pretty much says it all. LOL
jmaynard
PostPosted: Thu Apr 16, 2009 7:16 am    Post subject: First real result of the NTSB report Reply with quote
That's correct. See 61.403: a CFI-SP only needs a sport pilot certificate,
and does not need to have a medical at all.
A regular CFI doesn't need a second class medical, either; he only needs a
third class medical to give instruction if he's acting as PIC, else he needs
no medical at all. You can take the commercial pilot test with a third class
medical, as well; you only need the second class medical to exercise
commercial pilot privileges - and instruction is not among them.
Jay Maynard, K5ZC
notsew_evets(at)frontiern
PostPosted: Thu Apr 16, 2009 7:34 am    Post subject: First real result of the NTSB report Reply with quote
Absolutely correct on the CFI medical issue.
However, Are you sure you want to teach and sign off other people to fly.
Talk to insurance companies about your responsibilities and liability as a
CFI, CFI SP...
It aint worth the worry. Trust me.........
Steve.
Gig Giacona
PostPosted: Thu Apr 16, 2009 7:59 am    Post subject: Re: First real result of the NTSB report Reply with quote
CFI, CFI SP...
Steve.
Wow, I'll bet you are glad the guy that taught you to fly didn't feel that way.
W.R. "Gig" Giacona
jmaynard
PostPosted: Thu Apr 16, 2009 8:12 am    Post subject: First real result of the NTSB report Reply with quote
CFI, CFI SP...
I'll cross that bridge when I get to it. At the moment, there's no demand
for a CFI-SP in Fairmont. I also have the minor matter of an aircraft to
instruct in, and that aircraft won't be my Zodiac unless I get more than a
few students to pay the $8000+ insurance bll for the airplane.
With that said, my goal in getting the rating is to share my love of flying
with others, and also, and not coincidentally, to improve my own abilities
as a pilot. My own flying has improved quite a bit just in the time I've
been working on the rating. Teaching also helps the teacher as well as the
student; just ask any CFI about that.
Jay Maynard, K5ZC
PostPosted: Thu Apr 16, 2009 10:52 am    Post subject: First real result of the NTSB report Reply with quote
Times have changed. Liability issues changed.
Actually I taught myself to fly. That was a few decades ago.
I even recommended myself for the CFI rating and the FAA issued it to me...
Go figure....
