drill bit for A6 pop rivet?
carlossa52(at)gmail.com
PostPosted: Thu Apr 16, 2009 5:22 am    Post subject: drill bit for A6 pop rivet? Reply with quote
Can someone confirm that the drill bit for A6 rivets is #10?
Carlos
CH601-HD, plans
working on centre wing
hansriet
PostPosted: Fri Apr 17, 2009 10:45 am    Post subject: Re: drill bit for A6 pop rivet? Reply with quote
I'm not an expert, but you'll find a drill bit size chart at this site:
http://bobmay.astronomy.net/misc/drillchart.htm
Gig Giacona
PostPosted: Fri Apr 17, 2009 11:53 am    Post subject: Re: drill bit for A6 pop rivet? Reply with quote
The memory isn't what it used to be but for some reason I'm think 3/16th is what I used.
Carlos
CH601-HD, plans
W.R. "Gig" Giacona
601XL Under Construction
PostPosted: Fri Apr 17, 2009 12:20 pm    Post subject: drill bit for A6 pop rivet? Reply with quote
Good news: your memory is still good.
BTW, the answer was in ZAC's documentation: http://www.zenithair.com/kit-data/use-tls.htm
Carlos
2009/4/17 Gig Giacona <wrgiacona(at)gmail.com (wrgiacona(at)gmail.com)>
[quote] --> Zenith-List message posted by: "Gig Giacona" <wrgiacona(at)gmail.com (wrgiacona(at)gmail.com)>
> Thanks
> Carlos
> CH601-HD, plans
Gig Giacona
PostPosted: Fri Apr 17, 2009 12:35 pm    Post subject: Re: drill bit for A6 pop rivet? Reply with quote
No one is more surprised than I am that I was right.
Carlos
W.R. "Gig" Giacona
