cedavis
Posted: Sun Apr 19, 2009 11:41 am Post subject: Firefly Project |
Well, I've finally admitted that FLYING the firefly was to much fun, and I just was not going to ever assemble the 2d one. This is more then Kolb kits # 1 & 2 with a quick build, for a lot less.
Please pas to any one interested:
I've post the following on Barnstormers.com: KOLB FIREFLY PROJECT • $4,000 • CLEANING OUT THE HANGAR • Fly the hottest 103 UL (at)1/2 off!! Partially assembled Firefly with extras. List price > $8.5k • Contact Charles E. Davis, Owner - located Malvern, PA USA • Telephone: 610 731 9608 .
This is a perfect opportunity for some one looking for a Firefly at a reasonable price. All the difficult construction and fabrication are done. Little more then "bolt together and fly".
The sale includes:
1. Wings, including 9 in ailerons (Ready to paint & wired for wingtip strobes. Includes all lift struts and mounting hardware.)
2. Boom and tail feathers, assembled and painted.
3. Cables, rigged.
4. Cage. Cage was slightly damaged in a nose over and requires welding to replace two bent. The replacements tubes direct from Travis at Kolb are included.
5. Nosecone
6. Altimeter, Compass, and ASI
7. Sufficient covering materials for cage.
8. All needed miscellaneous parts to complete a firefly excepted as listed below.
9. Kuntzleman strobes and hotbox.
10. Original construction manual
What's not included?
1. Engine
2. Landing gear legs.
3. Loose AN hardware (Note: most of the AN hardware is already included in the assembled components)
Looking forward to a great spring & summer flying, not building.
Chuck
Chuck
