Flap stop
hansriet
PostPosted: Tue Apr 28, 2009 5:31 pm    Post subject: Flap stop Reply with quote
For a change a question about building:
I just watched a video shot during one of the open days in 2008 where Gus demonstrates a walk around. He mentions and shows a FLAP stop (not an aileron stop), but I can't find that part on the drawings to save my life. Anybody has some more info on this?
Hans
craig(at)craigandjean.com
PostPosted: Tue Apr 28, 2009 5:49 pm    Post subject: Flap stop Reply with quote
Page 6-S-3 of the plans (dated 03/06), "FLAP GAP STOP". It is made of Nylon.
-- Craig
jaybannist(at)cs.com
PostPosted: Tue Apr 28, 2009 5:51 pm    Post subject: Flap stop Reply with quote
Hans,
The flap stop is a rectangular piece of nylon (1/8" x 90mm x 25mm) that is riveted underneath to the overhang of the wing top skin. It restricts the upward movement of the flap. In the flap up position, the nose of the flap should be tight against this stop. It is shown on Drawing 6-S-3. It is actually called "Flap Gap Stop".
Jay Bannister
cookwithgas
PostPosted: Tue Apr 28, 2009 6:34 pm    Post subject: Re: Flap stop Reply with quote
Hans:
I flew my 601XL about 50 hours before I realized the flap stop was missing. One of my flaps was loose and would wiggle during run-up but it never made a peep during flight. I finally put the stops so the flaps came up against the little nylon rectangle. It is a snap to install and only takes a few minutes.
Thanks for staying on the subject of building and flying the 601XL. I'm so sick of the blah blah this list has become.
Scott Laughlin
Omaha
601XL/Corvair
123 hours.
bryanmmartin
PostPosted: Tue Apr 28, 2009 7:25 pm    Post subject: Flap stop Reply with quote
I have an early set of plans and I couldn't find it on my plans
either. In fact, I flew my plane for over two years and 150 hours
without them. When I realized they were supposed to be installed, I
simply drilled out three rivets in the upper trailing edge of the wing
at the outer end of the flap and installed two pieces of nylon. It
took about half an hour. Before I installed them, the outer end of the
flap would flex upward slightly in flight, but it never caused any big
problem. Now the outer end of the flaps make contact with the nylon
stop just before the flaps hit the up limit switch.
Hans
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
hansriet
PostPosted: Tue Apr 28, 2009 8:05 pm    Post subject: Re: Flap stop Reply with quote
Thanks for all the feedback guys.
Hans
