Optical Low Fuel Sensor
napierm(at)cisco.com
PostPosted: Sun Apr 19, 2009 12:04 pm    Post subject: Optical Low Fuel Sensor Reply with quote
This is in the archives, I did a quick search, but is worth asking
again.
I have the optical sensor Skystar supplied some time back.
The part number is VP03E which from the Carlo Gavazzi datasheet is a
Polymide 12 plastic.
In a web search I see mixed data for this plastic when used with
ethanol.
I'm redoing my header system due to an engine swap and want a low fuel
warning. Is it OK to use or should I junk it and get something else?
Is there any hard data one way or the other?
Mark Napier
Eggstaf(at)aol.com
PostPosted: Thu Apr 23, 2009 10:08 am    Post subject: Optical Low Fuel Sensor Reply with quote
Ethanol laced gasoline melted that optical sensor right out of my header tank. Fuel in the belly of the plane. I replaced it with a float switch Carlo Gavazzi # FSH-34 that the distributor thought would hold up in ethanol but they weren't sure. I tested it by soaking it in auto fuel for 2 weeks. Seems OK. I now only use avgas with TCP added. Don't want to take a chance with ethanol! I also had several other problems with ethanol that I posted here earlier.
Lloyd Eggstaff
Big Island Hawaii
Vixen ECV001
100 HP Rotax
N100VX
Access 350+ FREE radio stations anytime from anywhere on the web. Get the Radio Toolbar!
