		hotwheels
				 Posted: Wed Apr 22, 2009 12:08 pm    Post subject: cowl heat shield photos? |
				Does anyone have photos of their cowl heat shield install?
 I'm planning to cover the entire inside cowl area with high temp sealant... Then apply heat shield material only on the bottom cowl.
 Jay
		Tim Olson
				 Posted: Wed Apr 22, 2009 12:50 pm    Post subject: cowl heat shield photos? |
				You're going to apply WHAT to the entire inside cowl area??
 Sealant??  I'm not following what this would be to accomplish,
 other than add weight.  It would be lighter to apply just
 heat shield.  The only people who have had issues that
 I know of didn't have any heat shield in the required areas.
 Or by sealant do you just mean some sort of light epoxy to
 seal the holes?
 jayb wrote:
  Thanks, Jay
  http://forums.matronics.com/viewtopic.php?p 40786#240786
		hotwheels
				 Posted: Wed Apr 22, 2009 1:45 pm    Post subject: Re: cowl heat shield photos? |
				Planning to use epoxy based high-temp primer on the inside of the cowl as has been discussed in this forum recently.
 Jay
		Tim Olson
				 Posted: Wed Apr 22, 2009 4:22 pm    Post subject: cowl heat shield photos? |
				Ahhh, sorry.  I saw SEALANT and thought RTV.  I see you mean
 epoxy based sealER...that makes perfect sense.  My bad.
		nukeflyboy
  Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
				 Posted: Thu Apr 23, 2009 10:09 am    Post subject: Re: cowl heat shield photos? |
				Tim tripped over the same verbiage I did.  But let's not leave it at that.  What do you mean by "heat shield"?  If you are referring to the adhesive backed reflective material (like aluminum tape) that Van's sells then OK.  If you mean something else, then what is it?
  _________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
		n223rv(at)wolflakeairport Guest
				 Posted: Thu Apr 23, 2009 10:53 am    Post subject: cowl heat shield photos? |
				FWIW, I used the sticky backed heat shield from Van's in my RV-4
 cowl.  After several hours of use, the heat melted the adhesive and
 most of it came loose.  I purchased more and the second time I
 squeegied a thin layer of high temp silicone over the sticky backed
 adhesive, layed it in place and used a plastic squeegie to smooth it
 out.  It hasn't moved in 300 hours......  I'm going to do the same on
 the -10.
 On Apr 23, 2009, at 2:09 PM, "nukeflyboy" <flymoore(at)charter.net> wrote:
  Dave Moore
  RV-6 flying
  RV-10 QB - cabin top/fiberglass hell
  http://forums.matronics.com/viewtopic.php?p 40931#240931
		hotwheels
				 Posted: Fri Apr 24, 2009 6:34 am    Post subject: Re: cowl heat shield photos? |
				1) Apply thin coat of Acetone thinned epoxy
 2) Cover with 1200 degree outdoor grill paint (Home Depot)
 3) Apply Van's self-stick aluminum foil with edges RTV'ed for areas next to exhaust
  	  | nukeflyboy wrote: | 	 		  | Tim tripped over the same verbiage I did.  But let's not leave it at that.  What do you mean by "heat shield"?  If you are referring to the adhesive backed reflective material (like aluminum tape) that Van's sells then OK.  If you mean something else, then what is it? |
		nukeflyboy
				 Posted: Fri Apr 24, 2009 11:23 am    Post subject: Re: cowl heat shield photos? |
				Looks like a good plan.  I have used Van's reflective heat shield on my RV-6 and it works well.  It is only needed where the cowl is in close proximity to the exhaust pipes (say 3-4 inches).
RV-6 built and sold
