paulrod36(at)msn.com Guest
				 Posted: Fri Apr 24, 2009 10:58 am    Post subject: The breakups |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I'm OK with various people having various interpretations and differing  viewpoints, but in all I have read, I am still waiting for the following  data:  In each crash, has anybody identified the individual piece that  failed?  I seem to recall that one crash summary stated that the main spar  had failed, and been twisted, but there seems to be a dearth of information on  this.  as in: if the rear spar tore loose from the carry-through, for  instance, I'd look at either a thicker attach point plate, or two attach point  plates, on either side of the carry-through and the spar. If it's flutter, then  it seems reasonable to either pre-load the ailerons a couple of degrees down, or  use push-pull tubes insttead of cables. If we're looking at excessive G,  (positive or negative) then maybe more stringent elevator stops would be called  for.  If we're looking at excessive positive G, could that point to pilot  error? I have a hard time believing that somebody could not know when he's  pulling 4 or more G, no matter how light the stick force is. Since, I'm sure,  the FAA and NTSB have a set of plans, I'd love to see a call-out of the part  numbers that either failed or are broken, and are not attributable to ground  impact.  Until somebody comes up with that information, I guess I'll keep  building, albeit at a slower pace.
  Paul Rodriguez
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
