		tomhanaway
				 Posted: Sun Apr 26, 2009 3:36 am    Post subject: Dual static line runs? |
				Trutrak suggests that a large # of demands on static line may cause lag in auto pilot.  Their suggestion is to run two static lines forward to panel IF this occurs.
 My current panel is two AFS 4500's, one AFS 3400, 2&1/4" backup altimeter and airspeed, trutrak adi and vsvg2 autopilot , and 430w garmin stack for demands on static line.
 Has anyone actually found a need for a second static line (still using just  the original two static ports) or is one sufficient?
 I'd like to avoid second line but if I'm  going to run one, now's the time.
 Tom H.
		Tim Olson
				 Posted: Sun Apr 26, 2009 5:02 am    Post subject: Dual static line runs? |
				I used that Tygon tubing for static and I've not seen any problems
 even with at least 7 items tapped off of it.  I'm not sure if tubing
 size for other types of tubing would have an effect or not, but
 I can only say that what I'm using seems to be fine.  I'd give
 it a try I guess before you worry about pulling more lines, because
 unless you add 2 more static ports, I don't know that adding the
 additional volume of another line would be a good thing.
 tomhanaway wrote:
  <tomhanaway(at)comcast.net>
  time.
  Thanks, Tom H.
  http://forums.matronics.com/viewtopic.php?p 41293#241293
				 Posted: Sun Apr 26, 2009 5:06 am    Post subject: Dual static line runs? |
				I have not seen the need for 2 static lines.  If you are worried about
 it, you can put your Auto Pilot closest to the static port in your
 routing, then your EFIS, then your backup instruments.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 On Apr 26, 2009, at 7:37 AM, tomhanaway wrote:
  the time.
  Tom H.
		Tim Olson
				 Posted: Sun Apr 26, 2009 5:29 am    Post subject: Dual static line runs? |
				I'd keep the altimeter and air data instruments closest in all cases
 if you find any issues.  Knowing the correct altitude on an IMC
 approach is more important than how quickly the autopilot reacts.
 But, I doubt you'd have a problem.
 Jesse Saint wrote:
  Jesse Saint
  Cell: 352-427-0285
  Fax: 815-377-3694
 > time.
 > Thanks,
 > Tom H.
		rene(at)felker.com Guest
				 Posted: Sun Apr 26, 2009 5:55 am    Post subject: Dual static line runs? |
				I agree with Tim and Jesse and have not seen a need for it.  I also agree
 with Tim that I wonder if it even would do any good without another set of
 ports.....the tubing ID is so much bigger than the static port opening.  I
 am not a fluid dynamics expert....but I did stay in a Condo in Park City
 Last night.  I have the following off of may static system....
 Backup altimeter
 Backup ADI
 Backup AS indicator
 Autopilot
 Grand Rapids EFIS
 Blue mountain EFIS
 AOA
 My autopilot works great....
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
		Dick Sipp
				 Posted: Sun Apr 26, 2009 5:58 am    Post subject: Dual static line runs? |
				I would have to agree wtih Tim and Jesse, I also have multiple taps and all
 static related indications are
 very close.
 Dick Sipp
 N110DV 130 hours
		jim(at)CombsFive.Com Guest
				 Posted: Sun Apr 26, 2009 12:14 pm    Post subject: Dual static line runs? |
				That is weird.  Is this specified in the manuals?  There is no flow in either the static or the pitot system, only pressure.  Very low pressures to boot.  Is that something someone told you on the phone?really curious.Jim C--> RV10-List message posted by: "tomhanaway" <tomhanaway(at)comcast.net>Trutrak suggests that a large # of demands on static line may cause lag inauto pilot.  Their suggestion is to run two static lines forward to panelIF this occurs.My current panel is two AFS 4500's, one AFS 3400, 2&1/4" backup altimeterand airspeed, trutrak adi and vsvg2 autopilot , and 430w garmin stack fordemands on static line.Has anyone actually found a need for a second static line (still usingjust  the original two static ports) or is one sufficient?I'd like to avoid second line but if I'm  going to run one, now's thetime.Thanks,Tom H.Read this topic online here:http://forums.matronics.com/viewtopic.php?p 41293#241293   [quote][b]
		tomhanaway
				 Posted: Sun Apr 26, 2009 1:29 pm    Post subject: Re: Dual static line runs? |
				Jim, actually in writing. Page 2 of the vsvg2 install manual (see below).  Based on everyone's comments, it sounds like the single line has sufficient volume.  I'm using the safeair 1 system.
 Thanks to all. One more "mental demon" put to rest.
 Tom
 Pitot and Static Connections
 All multi-servo TruTrak autopilots require connections to the pitot and static lines. The preferred method of this connection
 would be tee fittings near the aircraft’s altimeter. The static line for the autopilot requires due care in its construction, as
 excessive lag or insufficient static orifices can cause the autopilot to oscillate (hunt) in pitch. Although there is compensation
 within the autopilot sufficient to handle moderate amounts of lag, the importance of a good static port and line cannot be
 overstated. In some cases problems can be caused by having a large number of devices (including the autopilot) connected to a
 single, insufficient, static port. In other cases, the static line itself is adequate but there are one or more devices connected to the
 same line, one of which has a large static reservoir. A simple remedy for this problem if it occurs is a tee-fitting near the static
 port, and a dedicated line to the autopilot only. Obviously, an insufficiently-large orifice coupled with large static reservoirs
 can aggravate the problems associated with lag.
				 Posted: Sun Apr 26, 2009 5:32 pm    Post subject: Dual static line runs? |
				I am currently installing an VSGV DII and missed that statement.  I could see where a older mechanical instrument might have a set of "Bellows" and that by itself could set up some pressure fluctuations.  The newer electronic EFIS units depend on mems based pressure sensors and would not have any such devices.  I have been focusing on the servo installation this weekend.  The connections to the control unit will happen this week.Comment for anyone currently running wiring.  Run ALL the wires you ever think you might need.  Going back and adding them is NOT a fun process.Thanks Tom for the post.Jim CombsN312F Flying (Soon with autopilot!)--> RV10-List message posted by: "tomhanaway" <tomhanaway(at)comcast.net>Jim, actually in writing. Page 2 of the vsvg2 install manual (see below). Based on everyone's comments, it sounds like the single line hassufficient volume.  I'm using the safeair 1 system.Thanks to all. One more "mental demon" put to rest.TomPitot and Static ConnectionsAll multi-servo TruTrak autopilots require connections to the pitot andstatic lines. The preferred method of this connectionwould be tee fittings near the aircraft’s altimeter. The static line forthe autopilot requires due care in its construction, asexcessive lag or insufficient static orifices can cause the autopilot tooscillate (hunt) in pitch. Although there is compensationwithin the autopilot sufficient to handle moderate amounts of lag, theimportance of a good static port and line cannot beoverstated. In some cases problems can be caused by having a large numberof devices (including the autopilot) connected to asingle, insufficient, static port. In other cases, the static line itselfis adequate but there are one or more devices connected to thesame line, one of which has a large static reservoir. A simple remedy forthis problem if it occurs is a tee-fitting near the staticport, and a dedicated line to the autopilot only. Obviously, aninsufficiently-large orifice coupled with large static reservoirscan aggravate the problems associated with lag.Read this topic online here:http://forums.matronics.com/viewtopic.php?p 41355#241355   [quote][b]
		wayne.e(at)grandecom.net Guest
				 Posted: Mon Apr 27, 2009 3:31 am    Post subject: Dual static line runs? |
				Tom,
  I used the Safeair system also and I have the  TruTrak Sorcerer auto pilot and a bunch of other static required  instruments and I've had no problems at  all. I've also had my instruments IFR certified and they found no  problems.
  Wayne Edgerton
  N602WT  flying
