bushings
carlossa52(at)gmail.com
PostPosted: Tue Apr 28, 2009 7:03 pm    Post subject: bushings Reply with quote
The 601HD(S) plans call for bushings in the aileron bell crank installation and on the rudder bearings (at least, these are the ones I can remember). Very similar (if not exactly the same) to this XL drawing http://www.zenithair.com/zodiac/xl/data/sample-6w10.pdf
Question for scratch builders: what did you use as a bushing? I looked at tubes in the AS&S catalog, but did not find a (exact) match...
I'd appreciate your input
Carlos
CH601-HD, plans
Gig Giacona
PostPosted: Wed Apr 29, 2009 5:09 am    Post subject: Re: bushings Reply with quote
I don't know if they have exactly what you need but I came across a bunch of bushings at Wicks.
W.R. "Gig" Giacona
601XL Under Construction
steerr(at)bellsouth.net
PostPosted: Wed Apr 29, 2009 5:26 am    Post subject: bushings Reply with quote
I ran out of bushing material when I was building my HD and Zenith sent
me more. I have some left over (somewhere). You're welcome to it if
you want it.
Bill
N109BS
Jeyoung65(at)aol.com
PostPosted: Wed Apr 29, 2009 5:40 am    Post subject: bushings Reply with quote
Spruce's p/n is 03-00250 for the 4130 steel tubing,cut to length. 1/4" O.D. with .028 wall. Jerry of GA
In a message dated 4/28/2009 10:03:58 P.M. Eastern Standard Time, carlossa52(at)gmail.com writes:
Carlos
CH601-HD, plans
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matron====================================
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Big savings on Dell XPS Laptops and Desktops!
JohnDRead(at)aol.com
PostPosted: Wed Apr 29, 2009 6:07 am    Post subject: bushings Reply with quote
Hi Carlos;
�Zenith has that tube, they will sell you a short length.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
Access 350+ FREE radio stations anytime from anywhere on the web. Get the Radio Toolbar!
