cloudvalley(at)comcast.ne Guest
Posted: Wed Apr 29, 2009 6:17 am Post subject: Percent power. How to calculate? . . . Survey says! |
Hi Cliff,
I thought you didn't worry about manifold pressure; just get to about 2500RPM or so and then pull out the mixture til rough and back in slightly..smile
Brian
flyv35b(at)minetfiber.com Guest
Posted: Wed Apr 29, 2009 7:40 am Post subject: Percent power. How to calculate? . . . Survey says! |
I don't WORRY about it. But I use it for setting the power level. And yes, I do lean to rough and then back in slightly until it smooths out. RPM will depend on what altitude you are at and how much power you want. Up high I would run pretty much at 2700 rpm.
Cliff
