52TW - Main Tires & Tubes
david(at)mcgirt.net
PostPosted: Mon Jan 09, 2006 6:17 am    Post subject: 52TW - Main Tires & Tubes Reply with quote
Ok, time to replace the mains on my 52TW – one recommendation I have is for Condor 600x6 6ply tires, and Goodyear tubes..
Anyone else have better thoughts on this one?  Thanks..
David McGirt
Yak 52 TW
yak52driver(at)earthlink.
PostPosted: Mon Jan 09, 2006 3:11 pm    Post subject: 52TW - Main Tires & Tubes Reply with quote
David
You have two choices if running the stock rims. Desser tires or the original Russian. The Russian tires are better. You can get them from Jill & Carl Hays at www.m-14p.com
If you have non-stock rims then I can't help you.
Frank
dsavarese(at)elmore.rr.co
PostPosted: Mon Jan 09, 2006 5:40 pm    Post subject: 52TW - Main Tires & Tubes Reply with quote
Frank,
The Russian tires won't fit the Cleveland rims on the TW.
Dennis
