craigb(at)onthenet.com.au Guest
Posted: Tue May 05, 2009 1:53 pm Post subject: Europa-List: Europa Original Seat Beltsī Inherent Risk |
Ramio, for what its worth, having rolled my own race car once I understand what you are saying, even the "race" harnesses
can get a bit tight to undo when you are upside down, but in australia you can get a "life hammer" as they call it
its designed to easily cut belts in one go without cutting the wearer of the belt, and to break toughened glass. Obviously
the breaking glass bit wont work on plexi but if its mounted on the roof or panel should still be easliy reached when you
are upside down. But lets all hope that we never "land" in that position.
craig
[quote] --
Posted: Tue May 05, 2009 3:13 pm Post subject: Europa-List: Europa Original Seat Beltsī Inherent Risk |
Raimo...Before I discard my beloved Europa seat belts, I will make test when fuselage is rigged on my rotisserie...I will attempt break out from harness when inverted and report back...first I will place 3 pillows on floor below my head.
Of course in the event of crash and inversion, since I have raised the level of the pivot point of the shoulder harness on the raised portion of the seat back with my little gizmo, I anticipate being fully mobile and not to have suffered any spinal trauma which would otherwise hinder my ability to release myself from the harness and exit the aircraft...a detail not to be overlooked when considering optimum conditions for survivability.
Fred
A194
On May 5, 2009, at 10:18 AM, Raimo Toivio wrote:
| Quote: | All who use or are going to use Europa original seat belts
There is also one another (one is the potential hip hit in accident) safety problem with Europa-type belts and installation:
They form a fixed loop around your shoulders.
In the case of accident if you are upsidedown it is hard or even impossible to escape.
That may be very difficult even in a car with just an ordinary three point seat belts.
Think:
- after ditching or any bad landing you may be upside down. What kind of last moments you have before drowning or burning or starving if you cannot escape because of unlockable safety belts?
After certain this category fatal accidents those type "loop" belts have been illegal and strictly forbidden in Finland since 2001. That order is also valid for experimentals and ultralights.
I do not know the actual situation in other countries.
That is why I have German made Schroth TSo belts with central lock and four fully separate laps.
I wish you all have anyway minimum a lap knife in a practical place near by.
I hope nobody will suck a pea into her/his nose because of my message!
Wishes, Raimo OH-XRT
PS: I have one free free set of Europa belts for anyone but they are definetely not for aviation use!
-- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean. [quote][b]
raimo.toivio(at)rwm.fi Guest
Posted: Wed May 06, 2009 3:00 am Post subject: Europa-List: Europa Original Seat Beltsī Inherent Risk |
Thanks Graig for understanding.
I have in my cars similar belt cutters behind sun vizors.
To survive
- you have to understand you need it
- you have to remember where it is
- you have to reach it
- you have to be able to use it physically
After hard experiences all of this points could be difficult to complete.
We buy all kind of unnecessary toys to make us happy.
Why donīt we buy something (safer safety belts) which could save our life.
As alive it is easier to be happy and play with those toys.
BTW what about safety belts with Airbags then...you know statistics.
Letīs do so.
Raimo OH-XRT
PS: one possible scenario:
Prop is feathered for gliding.
You cannot unfeather it.
Forced landing follows.
Prop blades are very strong when in feathered position.
If they will hit somewhere, plane will go uppside down almost surely.
This "warning" is in the Airmaster Operatorīs Manual.
Posted: Wed May 06, 2009 3:11 am Post subject: Europa-List: Europa Original Seat Beltsī Inherent Risk |
Fred, great!
Raimo...Before I discard my beloved Europa seat belts, I will make test when fuselage is rigged on my rotisserie..I will attempt break out from harness when inverted and report back...first I will place 3 pillows on floor below my head.
Please please take a video from that mission!
Goog luck - you are a real hero if you really do that!
Remember to remove planeīs door before that test and please use helmet!
And do not do it alone
I will copy if you mind your "little gizmo" during next winter delay.
Raimo OH-XRT
PS: should you first try with a sand sack which is about same weight like you?!
Fred
A194
Think:
believed to be clean. | Quote: |
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
