Tunnel grounding
woxofswa
PostPosted: Mon May 04, 2009 10:42 am    Post subject: Tunnel grounding Reply with quote
Hi guys,
This is my first post on this forum. I am looking forward to learning at the knees of the braintrust.
I just finished the 'lectric bible and really enjoyed it, (that which I could understand at least).
I am building an RV-10 and have settled for now on the one battery two alternator scheme, and am planning to run a #2 ground wire from the (rear) batt to a forest of grounds at the firewall.
I got started by buying the Van's wiring kit just to get my feet wet.
My specific question for today has to do with grounding items in the center tunnel, specifically, the fuel totalizer, fuel pump, flap actuator, flap position selector, and a flap position sensor (wouldn't it be great if those two could be combined into one geewhiz?)
At any rate, the question that I have on grounding those items is should I:
1. Ground each locally?
2. Run a separate ground for each to the front forest?
3. Run each to a mini forest in the tunnel that has its own ground wire to either the front ground forest or back to the battery?
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse in progress
MauleDriver(at)nc.rr.com
PostPosted: Mon May 04, 2009 12:20 pm    Post subject: Tunnel grounding Reply with quote
Myron, I'm not an expert here but since I'm knee deep in my '10, I
thought I'd share my thinking and doing at this point....
- I'm locally (on the tunnel structure) grounding all of the items you
mentioned except for my GRT fuel flow sensor which is grounded on my
forest of tabs. I figure the fuel flow sensor might be sensitive to
ground issues.
- I have my 2 batteries well grounded to the airframe using the approach
Bob has documented on his site
http://www.aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html
- I have a forest of tabs on the firewall but I ran a #8 cable to it.
Most of my panel is run to it. I'm depending on the engine being well
grounded through the airframe for starting so I figure I don't need more
than a #8.
btw, the FAA's Acceptable Methods has great detail on how to do airframe
ground connections (lock washers, materials, etc)
Hope some of that helps.
Bill "going to run some wires" Watson
RV10 40605
woxofswa wrote:
Hi guys,
Thanks in advance.
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p 42685#242685
woxofswa
PostPosted: Fri May 08, 2009 5:05 pm    Post subject: Re: Tunnel grounding Reply with quote
Thanks Bill,
I appreciate your suggestions, but I am still hoping that Bob also chimes in before I finish out the tunnel.
Best,
Myron Nelson
Mesa, AZ
PostPosted: Fri May 08, 2009 9:03 pm    Post subject: Tunnel grounding Reply with quote
At 08:05 PM 5/8/2009, you wrote:
--> AeroElectric-List message posted by: "woxofswa" <woxof(at)aol.com>
Thanks Bill,
I thought I had responded to this but I don't
find the response on my computer here at home.
Perhaps I crafted something on a trip machine
and never got it sent. Anywho . . .
Not really necessary in an all metal airplane but
works good . . .
None of these are especially vulnerable to
ground loop noises so local grounds will probably
be fine. The super clean approach is separate
ground wires for each device to the forest
of tabs on the firewall.
( -Thomas Paine 1776- )
woxofswa
PostPosted: Sat May 09, 2009 2:27 pm    Post subject: Re: Tunnel grounding Reply with quote
Thanks Bob.
I like super clean.
Myron Nelson
Mesa, AZ
