		KeysFox
				 Posted: Mon May 04, 2009 1:24 pm    Post subject: Wheels |
				I HAVE ESTIMATES OF $300 and $500 to weld brake disc attachment lugs on a new Douglas wheel for my for my
 Kitox IV
 Anyone have a less costly shop that can Get it done
 B Jones
 N154K
 443 480 1023
 Sent from my Verizon Wireless BlackBerry
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ B Jones
N154K
443-480-1023 |
		peteohms
				 Posted: Mon May 04, 2009 2:21 pm    Post subject: Wheels |
				I know where you can get the wheels tires and brakes and landing gear
 assembly for $500.
 Pete
 Hell Paso
  _________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
		kitfox(at)bresnan.net Guest
				 Posted: Tue May 05, 2009 6:19 am    Post subject: Wheels |
				Pete , I would be very interested in that set , if  he is not ! Please let
 me know .
		peteohms
				 Posted: Tue May 05, 2009 6:50 am    Post subject: Wheels |
				DeWayne, I'll contact the owner and give him your email address.
 Pete
Leander, TX
		akflyer
				 Posted: Tue May 05, 2009 8:20 am    Post subject: Re: Wheels |
				that is robbery plain and simple.  It should take no more than an hour, to weld on 6 lugs.  It he was real slow it may take 2 hrs TOPS.  The average shop rate around here is 90.00 hr.  So you should be able to get them done for well under 200.00  I think a buddy paid about a 100.00 to get his done.
  _________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
		lcfitt(at)sbcglobal.net Guest
				 Posted: Tue May 05, 2009 11:13 am    Post subject: Wheels |
				Leonard,
 I wonder if $100 would do it.  I have often thought of how I would do it.
  	  | Quote: | 	 		  From what I have experienced with the wheels supplied by Denney and later
 Skystar, these are precision units.  Clunky, Yes, but precision
 never-the-less.  The rotor fits snugly and the holes line up in any rotor
 postion - and most importantly the rotor spins true.
 Quick and dirty would give very poor rotor alignment unless you had the
 already shaped and drilled tabs in stock that could be jigged and welded.
 This, of course means you would either have to fabricate the jigs or have
 them on hand.  All this costs.  Let's see - fabricate six lugs,  drill and
 tap them,  position them precisely, weld in place, check for accuracy -
 start over again.
 I agree that $400 is a lot of money, but we are talking here of a production
 run of two.    I would love to see the $100 wheels.
 Lowell
		Lynn Matteson
				 Posted: Tue May 05, 2009 1:58 pm    Post subject: Wheels |
				I see a lathe being brought into service here....for the truing up of
 the lugs' surfaces after the welding. The radial positioning of the
 lugs' holes would have to be assured with a jig, but a small amount
 of radial runout would not be TOO big a deal, but best to start with
 a perfect radial runout and let the temperature have its way with it,
 then chuck up the wheel and do a cleanup facing cut, and collect the
 man's money. : )
 Lynn Matteson
 Jabiru 2200, #2062, 644.7 hrs
 Sensenich 62x46 Wood prop
 Status: flying
 On May 5, 2009, at 3:11 PM, Lowell Fitt wrote:
  <lcfitt(at)sbcglobal.net>
  Leonard,
  do it.
 > and later
  rotor postion - and most importantly the rotor spins true.
  the already shaped and drilled tabs in stock that could be jigged
  and welded. This, of course means you would either have to
  fabricate the jigs or have them on hand.  All this costs.  Let's
  see - fabricate six lugs,  drill and tap them,  position them
  precisely, weld in place, check for accuracy - start over again.
  production run of two.    I would love to see the $100 wheels.
  Lowell
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		jdmcbean(at)kitfoxaircraf Guest
				 Posted: Tue May 05, 2009 2:35 pm    Post subject: Wheels |
				I'll try again.. Seems the last email did not go through.
 We can weld them. Give us a call.
 Fly Safe !!
 John & Debra McBean
 Ph 208.337.5111
 www.kitfoxaircraft.com
 "The Sky is not the Limit...  It's a Playground"
		akflyerbob
  Joined: 06 Jan 2008 Posts: 30 Location: Soldotna, Alaska
				 Posted: Tue May 05, 2009 6:02 pm    Post subject: Re: Wheels |
				I'm the buddy Leni is talking about.
 I made the weld lugs,drilled and tapped and bolted to the disks.
 Used a 3/4 bolt as an axel installed in the hub, hub bolted in the
 wheel ( now the other three holes can be drilled in the wheel)
 The head of the bolt clamped in a vice so the wheel can be rotated
 to align the brake disk. A little filing for alignment and welded.
 Their straight and work fine.
 It was simple but if I could buy them I wouldn't do it again. My wheels
 won't fit another fox with out wheel spacers aligning rotor to caliper.
 Cost me $130 for 1 1/2 hr of welder/shop time
 Bob
  _________________ Bob Wolfe..Soldotna, Alaska
KF Mod I and III |
		malpass
  Joined: 27 Aug 2007 Posts: 39 Location: Marietta, Georgia
				 Posted: Tue May 05, 2009 6:51 pm    Post subject: Wheels |
				roger that.  I can see what made it tough for you.
 I just bought a new douglas wheel like my old one and proceeded like I had
 mentioned before.  The rotor , bolts and old lugs where the template, it was
 a matter of cutting off the old lugs and rewelding making sure the inset
 diminsion was accurate.  I had no runout at all so mine was successful.  You
 want to avoid the redneck welders though.
 Bill
  _________________ kitfox III w/ 582 greyhead |
		akflyer
				 Posted: Wed May 06, 2009 11:11 am    Post subject: Re: Wheels |
				 	  | lcfitt(at)sbcglobal.net wrote: | 	 		  Leonard,
 start over again.
 Lowell
 We build entire pipe systems everyday that bolt in and fit with 0 tolerance,  a brake rotor is not a huge undertaking.  I guess I am just a get it done guy and don't spend alot of time analyzing every thing that could go wrong.  I just roll my sleeves and get'er done.  No need for me to put things on paper or look at it a hundred ways from sunday 99% of the time, just get an idea and run with it.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
		rob10(at)tlb.sympatico.ca Guest
				 Posted: Wed May 06, 2009 5:07 pm    Post subject: Wheels |
				I have a set of wheels with the lugs already welded  on and the turf tires for sale.
  Contact me off list if interested : rob10(at)tlb.sympatico.ca (rob10(at)tlb.sympatico.ca)
  Jack-Classic-1V-1200
