ron.mcgann(at)baesystems. Guest
Posted: Tue May 05, 2009 3:44 pm Post subject: Phase 1 report and GRT with the 'leans' |
G’day all,
Phase 1 flight testing is complete. As others that are flying already well know, this one sensational aircraft!! My stick time has been limited, but just supporting the ‘mandatory crew’ testing of Vx/Vy and gross weight has furthered my grin! Keep pounding those rivets – it is really well worth the effort.
Here is my squawk list (if you can call it that):
<![if !supportLists]>a. <![endif]>had to replace a valve core to stop left main deflating
<![if !supportLists]>b. <![endif]>adjusted governor to correct underspeed at full throttle
<![if !supportLists]>c. <![endif]>added fixed rudder trim
<![if !supportLists]>d. <![endif]>added fixed aileron trim (very small amount) to account slightly heavy right wing
<![if !supportLists]>e. <![endif]>removed a bug (literally!!) from the left tank vent line that fully blocked the vent. I have seen photos of an RV8 with a crushed tank that resulted from the vent being blocked and the vacuum created by pumping out the fuel – makes for a very bad day. The bug must have crawled in during the VERY brief period in which the tanks were empty for fuel calibration. CHECK THOSE VENTS!
<![if !supportLists]>f. <![endif]>Dodgy CHT sensor (or connection)
<![if !supportLists]>g. <![endif]>My GRT EFIS presents a slight roll (~3degs) on some occasions. This is intermittent, not significant, just bloody annoying. The skid ball is also way out – no correlation to the mechanical ball at all.
I thought my GRT installation was pretty standard for a -10, the AHRS and magnetometer are located on a shelf aft and rear of the battery and A/P pitch servo. Plenty of distance from battery, antennas, A/P, mounted with non magnetic hw etc. The only magnetic item within cooee is the rear seat harness attach cables. Carols from GRT still believes it may be a magnetometer interference issue. Anyone else had similar problems, and how difficult is it to move the magnetometer to the wing tip while maintaining alignment with the AHRS?
Cheers
Ron
VH-XRM
Flying --- man THAT sounds good
[quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
tc1234c(at)roadrunner.com Guest
Posted: Tue May 05, 2009 4:19 pm Post subject: Phase 1 report and GRT with the 'leans' |
Ron,
On your point g. the GRT EFIS lean and skid ball problem, you may want to talk to Mark Allen at GRT. Early on I had the same problem with my 9A. After talking to Mark I sent him a log file. Based on the log file, Mark told me one of the sensor was off. They fixed that problem for me and it was more than 400 hours ago.
Ted
T.C. Chang
http://3limafoxtrot.com/
RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, left Mag + right Lightspeed EI, Sensenich FP
GRT dual DU H1, TT DigiFlight II VSGV, 572 hrs Hobbs
Last flight: http://www.mail2600.com/cgi-bin/track.cgi?call=KD8IIR&last=1
RV10 emp, #40948
Posted: Tue May 05, 2009 4:33 pm Post subject: Phase 1 report and GRT with the 'leans' |
Kudos Ron!!!
McGANN, Ron wrote:
| Quote: | G’day all,
It's news like this that keeps me going. >
| Quote: | Here is my squawk list (if you can call it that):=
a. had to replace a valve core to stop left main deflating
b. adjusted governor to correct underspeed at full
throttle
c. added fixed rudder trim
d. added fixed aileron trim (very small amount) to
e. removed a bug (literally!!) from the left tank vent
We have mud daubers where I live (FL) and they like tank vents with or
without fuel in the tanks!!! Take a pipe cleaner and bend it like a 'W'
and insert the middle bend up inside the vent. Should keep the critters
out.
f. Dodgy CHT sensor (or connection)
g. My GRT EFIS presents a slight roll (~3degs) on some
at all.
My thoughts on this are the distance between the yaw axis and the
mechanical ball Vs. the distance to the AHRS. Your AHRS is pretty far
aft, so the reading MAY be accurate ..... if it's really mounted correctly.
Linn
Cheers
Ron
VH-XRM
