KeysFox
Posted: Mon May 04, 2009 1:24 pm Post subject: Wheels |
I HAVE ESTIMATES OF $300 and $500 to weld brake disc attachment lugs on a new Douglas wheel for my for my
Kitox IV
Anyone have a less costly shop that can Get it done
B Jones
N154K
443 480 1023
Sent from my Verizon Wireless BlackBerry
_________________ B Jones
N154K
443-480-1023 |
peteohms
Posted: Mon May 04, 2009 2:21 pm Post subject: Wheels |
I know where you can get the wheels tires and brakes and landing gear
assembly for $500.
Pete
Hell Paso
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
kitfox(at)bresnan.net Guest
Posted: Tue May 05, 2009 6:19 am Post subject: Wheels |
Pete , I would be very interested in that set , if he is not ! Please let
me know .
peteohms
Posted: Tue May 05, 2009 6:50 am Post subject: Wheels |
DeWayne, I'll contact the owner and give him your email address.
Pete
Leander, TX
akflyer
Posted: Tue May 05, 2009 8:20 am Post subject: Re: Wheels |
that is robbery plain and simple. It should take no more than an hour, to weld on 6 lugs. It he was real slow it may take 2 hrs TOPS. The average shop rate around here is 90.00 hr. So you should be able to get them done for well under 200.00 I think a buddy paid about a 100.00 to get his done.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
lcfitt(at)sbcglobal.net Guest
Posted: Tue May 05, 2009 11:13 am Post subject: Wheels |
Leonard,
I wonder if $100 would do it. I have often thought of how I would do it.
| Quote: | From what I have experienced with the wheels supplied by Denney and later
Skystar, these are precision units. Clunky, Yes, but precision
never-the-less. The rotor fits snugly and the holes line up in any rotor
postion - and most importantly the rotor spins true.
Quick and dirty would give very poor rotor alignment unless you had the
already shaped and drilled tabs in stock that could be jigged and welded.
This, of course means you would either have to fabricate the jigs or have
them on hand. All this costs. Let's see - fabricate six lugs, drill and
tap them, position them precisely, weld in place, check for accuracy -
start over again.
I agree that $400 is a lot of money, but we are talking here of a production
run of two. I would love to see the $100 wheels.
Lowell
Lynn Matteson
Posted: Tue May 05, 2009 1:58 pm Post subject: Wheels |
I see a lathe being brought into service here....for the truing up of
the lugs' surfaces after the welding. The radial positioning of the
lugs' holes would have to be assured with a jig, but a small amount
of radial runout would not be TOO big a deal, but best to start with
a perfect radial runout and let the temperature have its way with it,
then chuck up the wheel and do a cleanup facing cut, and collect the
man's money. : )
Lynn Matteson
Jabiru 2200, #2062, 644.7 hrs
Sensenich 62x46 Wood prop
Status: flying
On May 5, 2009, at 3:11 PM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
Leonard,
do it.
> and later
rotor postion - and most importantly the rotor spins true.
the already shaped and drilled tabs in stock that could be jigged
and welded. This, of course means you would either have to
fabricate the jigs or have them on hand. All this costs. Let's
see - fabricate six lugs, drill and tap them, position them
precisely, weld in place, check for accuracy - start over again.
production run of two. I would love to see the $100 wheels.
Lowell
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
jdmcbean(at)kitfoxaircraf Guest
Posted: Tue May 05, 2009 2:35 pm Post subject: Wheels |
I'll try again.. Seems the last email did not go through.
We can weld them. Give us a call.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
akflyerbob
Joined: 06 Jan 2008 Posts: 30 Location: Soldotna, Alaska
Posted: Tue May 05, 2009 6:02 pm Post subject: Re: Wheels |
I'm the buddy Leni is talking about.
I made the weld lugs,drilled and tapped and bolted to the disks.
Used a 3/4 bolt as an axel installed in the hub, hub bolted in the
wheel ( now the other three holes can be drilled in the wheel)
The head of the bolt clamped in a vice so the wheel can be rotated
to align the brake disk. A little filing for alignment and welded.
Their straight and work fine.
It was simple but if I could buy them I wouldn't do it again. My wheels
won't fit another fox with out wheel spacers aligning rotor to caliper.
Cost me $130 for 1 1/2 hr of welder/shop time
_________________ Bob Wolfe..Soldotna, Alaska
KF Mod I and III |
malpass
Joined: 27 Aug 2007 Posts: 39 Location: Marietta, Georgia
Posted: Tue May 05, 2009 6:51 pm Post subject: Wheels |
roger that. I can see what made it tough for you.
I just bought a new douglas wheel like my old one and proceeded like I had
mentioned before. The rotor , bolts and old lugs where the template, it was
a matter of cutting off the old lugs and rewelding making sure the inset
diminsion was accurate. I had no runout at all so mine was successful. You
want to avoid the redneck welders though.
_________________ kitfox III w/ 582 greyhead |
akflyer
Posted: Wed May 06, 2009 11:11 am Post subject: Re: Wheels |
| lcfitt(at)sbcglobal.net wrote: | Leonard,
start over again.
Lowell
We build entire pipe systems everyday that bolt in and fit with 0 tolerance, a brake rotor is not a huge undertaking. I guess I am just a get it done guy and don't spend alot of time analyzing every thing that could go wrong. I just roll my sleeves and get'er done. No need for me to put things on paper or look at it a hundred ways from sunday 99% of the time, just get an idea and run with it.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
rob10(at)tlb.sympatico.ca Guest
Posted: Wed May 06, 2009 5:07 pm Post subject: Wheels |
I have a set of wheels with the lugs already welded on and the turf tires for sale.
Contact me off list if interested : rob10(at)tlb.sympatico.ca (rob10(at)tlb.sympatico.ca)
Jack-Classic-1V-1200
