Moose Fus 396
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List
ScottA
PostPosted: Thu Mar 23, 2006 2:55 pm    Post subject: Moose Fus 396 Reply with quote
Dave wrote:
>Does the fus 396 get riveted to the fuselage skin? Nothing in the
>instructions mentions it.
>Thanks,
>Dave Greaton Moose 189
This is the 396 that is the lower aileron pulley brackets correct?
Yes it does.  This is also part of the cause of the aileron slop in the Moose.  These lower pulleys flex and pull in and back when the tension gets tight on the cable.  Some guys have purchased extra 396's and put one on the front and back of the pulley to stiffen things up.  I did not do that but I made the support bracket (step 18, chapter 12, dated 7-11-02) out of steel instead of the raw stock .032 aluminum.  It helped a lot.   I wish I had beefed up the upper rear aileron pulley's  better than what is in the plans - the ones that attach to the fuselage/wing root area - these pull the sides of the fuselage in slightly also contributing to the slop.  I have determined nearly all of the slop or play in the ailerons is in the cable and pushrods inside the fuselage - not a whole lot of play out in the wing torque tubes.
FWIW
Scott
Moose 174
www.goflyamoose.com
- The Matronics MurphyMoose-List Email Forum -
http://www.matronics.com/Navigator?MurphyMoose-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List All times are GMT - 8 Hours
