				 Posted: Fri May 15, 2009 11:00 am    Post subject: MX20 Vertical stripes - update |
				I was finally able to replicate the problem with the primary alternator, secondary alternator, and more importantly - running on battery power alone.
 Contacted Garmin and they suggested I send the unit in - they replaced the display head and it is on its way back to me.
 Ralph
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		frank.hinde(at)hp.com Guest
				 Posted: Fri May 15, 2009 11:46 am    Post subject: MX20 Vertical stripes - update |
				Excellent,
 Sounds like it can't be an alternator noise problem then..I know whan I had painted steel alternator brackets (which produced high resistance ground path between the alt and the engine block) it played havoc with my GNS 430.
 Finally had the "duh" moment, changed the brackets and voila no more problems.
 Frank
