vincent.kollmannsberger(a Guest
Posted: Sun May 10, 2009 5:11 am Post subject: problem with my Baklan 5 radio |
Hello,
I have a problem with my Baklan 5 radio on my yak 52. No emission and no reception.
I saw on a forum that you had this problem. Can you tell me where I can find the fuse to change ?
Thank you
vincent
Please help Logica to respect the environment by not printing this email / Pour contribuer comme Logica au respect de l'environnement, merci de ne pas imprimer ce mail / Bitte drucken Sie diese Nachricht nicht aus und helfen Sie so Logica dabei die Umwelt zu schuetzen / Por favor ajude a Logica a respeitar o ambiente não imprimindo este correio electrónico. This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege. It should not be copied, disclosed to, retained or used by, any other party. If you are not an intended recipient then please promptly delete this e-mail and any attachment and all copies and inform the sender. Thank you. [quote][b]
Posted: Sun May 10, 2009 5:39 am Post subject: problem with my Baklan 5 radio |
The Baklan 5 radio has a circuit breaker (no fuse) on the left hand console. It is the last one in the series of 8 breakers and the one closest to the main air valve.
Dennis
vincent
Posted: Sun May 10, 2009 9:03 am Post subject: Re: problem with my Baklan 5 radio |
I see no problem with the switch N ° 1 "VHF" on/off ok
There's something special to do/ to check?
Posted: Sun May 10, 2009 11:13 am Post subject: problem with my Baklan 5 radio |
Most likely the radio unit has gone T.U.
Dennis
vincent
Posted: Sun May 10, 2009 12:28 pm Post subject: Re: problem with my Baklan 5 radio |
T.U ???
cjpilot710(at)aol.com Guest
Posted: Sun May 10, 2009 12:39 pm Post subject: problem with my Baklan 5 radio |
T.U. Means "TITS UP" or no longer working, inoperative, or broken in American slang.
Pappy
In a message dated 5/10/2009 4:30:05 P.M. Eastern Daylight Time, vincent.kollmannsberger(at)wanadoo.fr writes:
Recession-proof vacation ideas. Find free things to do in the U.S.
Posted: Sun May 10, 2009 1:47 pm Post subject: problem with my Baklan 5 radio |
It means "tits up" or in other words, broken.
Dennis
Posted: Sun May 10, 2009 4:05 pm Post subject: problem with my Baklan 5 radio |
Something in the back of my mind is telling me that there is also as fuse in the radio mount itself.
BUT.... since I do not own a YAK-52 and I don't have a mount right in front of me, don't quote me.
Mark Bitterlich
From: owner-yak-list-server(at)matronics.com on behalf of A. Dennis Savarese
Sent: Sun 5/10/2009 9:20 AM
To: yak-list(at)matronics.com
Subject: Re: problem with my Baklan 5 radio
Dennis
Posted: Sun May 10, 2009 6:43 pm Post subject: problem with my Baklan 5 radio |
The position your tits are in when your laid in the box or the position your
female was left in when you finished assuming missionary was where you
started. Tits up. Worn out. Deceased. Broken beyond repair.
Some more of that fighter pilot humor.
Doc
Rob Rowe
Joined: 10 Jan 2006 Posts: 124 Location: Berkshire, UK
Posted: Mon May 11, 2009 4:08 am Post subject: Re: problem with my Baklan 5 radio |
Vincent,
FWIW - from the -52 schematics (actual install could vary of course) there are no other fuses shown between the breaker and the Baklan 5.
However between the power bus and the breaker there is a 30 amp fuse that feeds the Baklan 5, intercom, gear/flap/lamp test lights, PAG1 inverter & the G meter ... if this has blown then I'm sure you would have noticed! In any case if it has then you would need to seek professional advice to fault find further.
brgds, Rob R
vincent
Posted: Wed May 13, 2009 6:30 am Post subject: Re: problem with my Baklan 5 radio |
There is a 10A fuse on the radio trail and it was out of service !
I changed the fuse and everything is ok!
thank you all for your help !!!
Posted: Thu May 14, 2009 3:46 am Post subject: problem with my Baklan 5 radio |
That's great. Sorry for sounding so dumb, but what is and where is the "radio trail" you mentioned. I would like to try and find this fuse in the schematics as well as the physical location. Thanks very much.
Dennis
vincent
Posted: Thu May 14, 2009 5:48 am Post subject: Re: problem with my Baklan 5 radio |
Hello,
The fuse is behind the rack of the radio amplifier behind the rear seat.
Posted: Thu May 14, 2009 5:53 am Post subject: problem with my Baklan 5 radio |
OK. Thanks Vincent. Much appreciated. I will check the Yak 52 schematics and see if I can find it.
Dennis
