ChangDriver
Posted: Mon May 11, 2009 10:11 am Post subject: Battery Charger as Ground Power |
Bob:
I've been reading some posts on ground power and noted that some people are using a battery charger as a ground power unit. From what I remember about the output voltage of almost all battery chargers, there is a significant potential to overvoltage the aircraft isn't there? The voltage from most chargers is not filtered and is not as clean as you'd want for powering avionics, etc.
Am I right,
Craig
woxofswa
Posted: Mon May 11, 2009 10:22 am Post subject: Re: Battery Charger as Ground Power |
I'm no expert, but I think you are right.
I think a 12.5 volt "maintainer" would make much more sense. They can be had at Harbor Freight for $5
For ground tests and assembly, I plan on using a cheapo lawn tractor battery with a maintainer hooked up to it. The battery would then serve as a sink if there is a problem with the maintainer.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Posted: Mon May 11, 2009 1:00 pm Post subject: Battery Charger as Ground Power |
At 01:11 PM 5/11/2009, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Craig Winkelmann" <capav8r(at)gmail.com>
Bob:
I've been reading some posts on ground power and noted that some people are using a battery charger as a ground power unit. From what I remember about the output voltage of almost all battery chargers, there is a significant potential to overvoltage the aircraft isn't there? The voltage from most chargers is not filtered and is not as clean as you'd want for powering avionics, etc. |
"Battery Charger" is non-qualified. Technically, any
source of energy that is capable of reversing current
flow into a battery is a 'charger'.
The quality of output power from chargers can be all
over the map. The very first charger I owned was a
6v Tungar rectifier electro-whizzy.
[img]cid:.0[/img]
The output quality of this thing would have been
REALLY noisy, ZERO voltage regulation, hideously
inefficient, but entirely suited to keeping my '41
Pontiac straight-6 ready to start on a cold morning.
By the way, anyone interested in exploring/reliving
some of the history of lead-acid battery technology,
feel free to download this item. (Caution 9+ MB)
http://tinyurl.com/owad89
45 years later and at the other end of the spectrum,
we can purchase light, relatively inexpensive, high
quality switch-mode power supplies that will serve as
both ground power supplies for system operations but
battery chargers as well.
Unfortunately, devices tailored to serve as "smart"
chargers (quick recharge, indefinite storage) probably
don't make good ground power supplies because their
internal battery-pampering software gets confused when
the "battery" being maintained keeps changing terminal
voltage and load.
A few years ago, we made a great buy on a quantity
of Samlex 1223 power supplies.
http://www.universal-radio.com/catalog/hamps/2423.html
We offered these as "alternator simulators" with the
suggestion that they could be used to make the ship's
systems believe that a 23A alternator was running.
This would allow the ship's battery to be charged
and ship's systems of up to 20A draw (about anything
but pitot heat) to be tested in the shop.
The short answer is that not all battery chargers
are suited for use as ground power supplies perhaps
due to their particular noise/voltage-regulation
characteristics. However, you can hook any charger
across a battery and give it a try. Make sure you
know how it behaves in the long term (watch bus
voltage) and know it's specific limits. With
a modicum of due-diligence, the experiment offers
minimal risk to system components.
( -Thomas Paine 1776- )
150.15 KB |
11423 Time(s) |
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27563 Location: Livermore CA USA
Posted: Mon May 11, 2009 2:33 pm Post subject: Battery Charger as Ground Power |
At 01:58 PM 5/11/2009 Monday, you wrote:
| Quote: | At 01:11 PM 5/11/2009, you wrote:
>Bob:
voltage and load.
I've got one of these Black and Decker BC40EB units that has adjustable charge output limits in addition to a 110amp starter booster. I'm plugging it into my GPU plug and use it to run the avionics, charge the battery, and I'm hoping eventually to jump start the engine when the battery is on the low side. The only downside seems to be that the unit has to see 4-5volts on the "battery" before it will turn on its output. This means that it won't flip the GPU relay and you have to have an external switch to do that.
Bob, does this seem like a good charger/GPU product for aircraft systems?
http://www.blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=17925
RV-8 #82880 N998RV
Carpet CAD Drawings...
(1200+ Hours Build Time...)
_________________ Matt Dralle
skywagon
Posted: Mon May 11, 2009 5:43 pm Post subject: Battery Charger as Ground Power |
The little, cheap Harbor Freight "maintainers" work quite well. I have used several. One key point however, ...many of them come set a tad too high in their fixed "float" voltage, to my thinking. I have seen them as high as 13.9 v.
The good news, is they can be adjusted to the float voltage that you want. The little controller box should have a back lid that is lightly glued in place. Carefully work a very narrow blade screw driver or other tough, but thin device into the glued seam and work it until the back pops off. Inside is a small circuit board and potentiometer. It may have a spot of RTV on it. Work this loose. Turning the pot CW lowers to float voltage. I like about 13.2 v. Others may want a slightly different setting. I usually locate where the pot slotted screw adjust hole is located next to the little case and drill a 3/16 hole. That way, it can be adjusted from the outside. The little unit is quite stable after you get the setting where you want it. David
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p 43569#243569
ChangDriver
Posted: Mon May 11, 2009 6:13 pm Post subject: Re: Battery Charger as Ground Power |
Bob:
Thanks, BUT some GPUs bypass the battery because they are not meant to be a port for charging the battery. In these cases, whatever comes out of the charger goes on the main bus. I suspect the right thing is to see how conditioned and stable the output voltage is prior to plugging the unit into a plane full of expensive avionics.
Craig
Posted: Mon May 11, 2009 7:42 pm Post subject: Battery Charger as Ground Power |
| Quote: | I think a 12.5 volt "maintainer" would make much more sense. They
Actually, the ideal maintainer voltage is just
above 100-200 millivolts the battery's open circuit
voltage 24 hours or so after taking it off the charger.
Lead-Acid batteries, this is 13.1 to 13.2 volts.
The idea is that you want to hold the battery at or
just above it's own chemistry voltage . . . thus
any and all tendencies to self-discharge are supported
by the external energy source. I.e. self-discharge
currents do not tax the chemistry. See:
http://www.aeroelectric.com/Pictures/Curves/Battery_Tender_Recharge.pdf
http://www.aeroelectric.com/Pictures/Curves/Ideal_Recharge_Protocol.jpg
Posted: Mon May 11, 2009 7:44 pm Post subject: Battery Charger as Ground Power |
At 09:13 PM 5/11/2009, you wrote:
Bob:
It's the system integrator's task to decide whether
or not the battery is on line during ground power
connection. I've heard the stories for both cases
for BIG airplanes with BIG batteries and BIG ground
power carts.
For our purposes and considering relative sizes
of our hardware, it's best to have a battery on
line during ground power ops . . . especially
if the power quality of the power source has not
been fully qualified to the task.
icubob(at)gmail.com Guest
Posted: Tue May 12, 2009 3:11 am Post subject: Battery Charger as Ground Power |
i have 6 or 8 of these little chargers on all my toys. i have noticed on some some that the voltage was too low. i tried once to adjust the voltage but couldn't get anything to turn.i guess i will go back and try again to adjust the voltage on a couple that are too low. on the one that was too high i soldered a diode in line and dropped the voltage.
bob noffs
On Mon, May 11, 2009 at 8:31 PM, David L. <skywagon(at)charter.net (skywagon(at)charter.net)> wrote:
[quote] --> AeroElectric-List message posted by: "David L." <skywagon(at)charter.net (skywagon(at)charter.net)>
---- woxofswa <woxof(at)aol.com (woxof(at)aol.com)> wrote:
--> AeroElectric-List message posted by: "woxofswa" <woxof(at)aol.com (woxof(at)aol.com)>
Myron Nelson
Mesa, AZ
http://forums.matronics.com/viewtopic.php?p=243569#243569
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Posted: Wed May 13, 2009 6:16 am Post subject: Battery Charger as Ground Power |
At 06:08 AM 5/12/2009, you wrote:
| Quote: | i have 6 or 8 of these little chargers on all my toys. i have noticed on some some that the voltage was too low. i tried once to adjust the voltage but couldn't get anything to turn.i guess i will go back and try again to adjust the voltage on a couple that are too low. on the one that was too high i soldered a diode in line and dropped the voltage.
bob noffs
The little, cheap Harbor Freight "maintainers" work quite well. I have used several. One key point however, ..many of them come set a tad too high in their fixed "float" voltage, to my thinking. I have seen them as high as 13.9 v.
The good news, is they can be adjusted to the float voltage that you want. The little controller box should have a back lid that is lightly glued in place. Carefully work a very narrow blade screw driver or other tough, but thin device into the glued seam and work it until the back pops off. Inside is a small circuit board and potentiometer. It may have a spot of RTV on it. Work this loose. Turning the pot CW lowers to float voltage. I like about 13.2 v. Others may want a slightly different setting. I usually locate where the pot slotted screw adjust hole is located next to the little case and drill a 3/16 hole. That way, it can be adjusted from the outside. The little unit is quite stable after you get the setting where you want it. David |
David's suggestions are worthy of consideration but
he doesn't mention specific model numbers from
H.F. I've tested several battery charger products
from H.F. and found some that were not suited to our tasks.
What we're looking for are devices that first
"top off" a battery and then "drop to maintenance".
This kind of behavior is illustrated in . . .
http://www.aeroelectric.com/Pictures/Curves/schumacher_3.jpg
This curve is from the Schumacher 1562 series chargers available
from WalMart for about $20. There are dozens of other
products that produce similar charge/maintenance profiles.
This one . . .
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42292
. . . does not.
I found a pot inside to adjust the output voltage . . .
but only ONE pot. It's a device suitable for maintaining
an already charged battery (adjust it for 13.1 volts) but
will not charge a battery.
Based on its description and price, this device
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=99857
shows more promise. Haven't had time to go get one and
check it out but in the mean time, the Schumacher
1562 is a sure bet
http://aeroelectric.com/Pictures/Battery_Chargers/Schumacher_Chargers/1562.jpg
Bob . . . [quote][b]
tonybabb(at)alejandra.net Guest
Posted: Fri May 15, 2009 1:16 pm Post subject: Battery Charger as Ground Power |
Hi Bob,
Perhaps you could help me understand what the words were that you saw in the advert that made you think HF item number 99857 might do the job (I understand you'd want to test it to confirm) versus very similar words in the ad for HF item number 42292 that you said definitely won't do the job. Both say they "maintain a full charge without over charging".
Below is the description for 99857 from the HF web site
[*]Three-stage fully automatic charging protects and prolongs battery life [*]Auto on/off trickle charging stage keeps 12 volt batteries fully charged without overcharging [*]Equipped with overload protection, short circuit protection, and reverse polarity protection for added safety [*]Also great for maintaining batteries while in storage [*]Has LED charge indicators [*]Includes a bracket for permanent mounting
and here's the description for 42292 from the HF web site
- Use on 12 volt batteries while in storage or during cold weather
- Floating circuit maintains a full charge without overcharging
- Automatic safety shutoff
Is there any way the electron challenged such as myself could tell or do we just have to buy and test - or follow your recommendations. Am I being naive in believing manufacturers claims?
Thanks for this and all your other explanations.
Tony Babb
