Posted: Sun May 17, 2009 4:59 pm Post subject: Fwd: Prepping fibreglass surfaces |
---------- Forwarded message ----------
From: David Saylor <dave.saylor.aircrafters(at)gmail.com (dave.saylor.aircrafters(at)gmail.com)>
Date: Sun, May 17, 2009 at 5:50 PM
Subject: Re: Prepping fibreglass surfaces
Scuffing with 80 grit then wiping with acetone is the standard prep before applying resin. 80g mechanically opens up the material, then the acetone washes and softens up the resin to make it ready for the resin.
On Sun, May 17, 2009 at 4:23 PM, Dave Leikam <daveleikam(at)wi.rr.com (daveleikam(at)wi.rr.com)> wrote:
[quote] Why would you want to apply anything to clean the surface? I am no expert but wouldn't a good scrubbing with 80-100 grit sand paper give a nice bare raw surface to apply epoxy to?
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
