malpass
Joined: 27 Aug 2007 Posts: 39 Location: Marietta, Georgia
Posted: Thu May 28, 2009 6:10 am Post subject: In flight adjustable props |
One thing to be cautious of installing the adjustable props, is that you will take a way the "light sport" qualifications of your aircraft, if that is important to you.
Bill Malpass
Kitfox model III 582 grey
Ivo 3 blade ground adjustable prop
_________________ kitfox III w/ 582 greyhead |
clint_bazzill(at)hotmail. Guest
Posted: Thu May 28, 2009 8:57 am Post subject: In flight adjustable props |
Only if the control for pitch is in the cockpit. If you already have your airplane certified no problem C when using with light sport C put the switch in the engine area C it becomes a ground adjustable electric prop.
Clint with IVO UL in 912ULS
Subject: In flight adjustable props
Date: Thu C 28 May 2009 10:02:29 -0400
One thing to be cautious of installing the adjustable props C is that you will take a way the "light sport" qualifications of your aircraft C if that is important to you.
Bill Malpass
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
