pictures...
avidsid(at)yahoo.com
PostPosted: Fri Mar 31, 2006 8:23 am    Post subject: pictures... Reply with quote
Lynn,
Its too late for the aforementioned photos, but check now to see if you digital camera has the "thumbnail" photo feature..........one that lets your camera create and store a smaller, email sized copy of the original high mb and pixel photo. Most digital cameras have the feature built in, but you need to chose it...........sometimes they will look blurry on your computer as you view them, but will come out okay to the end user and much smaller in megabyte size for quick internet exchanging and uploading.
Sid
-----------amateur everything
Lynn Matteson <lynnmatt wrote:
Don Pearsall just let me know that he has posted my 1st flight photos
on Sportflight, under First Flights. I had submitted them to him, then
added a retouched (Photoshop) version of the liftoff shot. That one is
huge! (I was having fun making the plane "move" by using the bottom
cursor, and supplying my own "airplane sounds" ...Jabiru, that is...you
Rotax guys have another sound. : ) )
I was lamenting the fact that when I shot the liftoff, the ground-level
wind indicator was right in the way of the rear fuselage, so I called
on my experiences with Photoshop, and took out the offending sock and
pole. I couldn't recall how to decrease the size of the file so sent it
out as a JPEG file of 328 KB. The others are smaller, and sent out as
Kodak EasyShare files of about 31 KB, although these numbers are not
reflected as such on the Sportflight site. If anybody knows how to make
a smaller file from a JPEG, let me know. I tried saving as a PICT, and
a TIFF, but the size did not apparently change.
Lynn
Kitfox IV...Jabiru 2200
"Why can't we all just get along?"
Lynn Matteson
PostPosted: Fri Mar 31, 2006 8:38 am    Post subject: pictures... Reply with quote
Thanks, Sid.
I'll look into that info. When I use EasyShare, as I mentioned, they
leave here at 31KB, and take about a minute or so each to send out on
my phone line, and are very viewable on the receiving end. I'll have a
look at the thumbnail option.
Lynn
On Friday, March 31, 2006, at 11:22 AM, Sid Hausding wrote:
Lynn,
Sid
Lynn
Kitfox IV-Jabiru 2200
N369LM
roncarolnikko(at)hotmail.
PostPosted: Fri Mar 31, 2006 8:51 am    Post subject: pictures... Reply with quote
I think hotmail accounts resize them automatically. Ron NB Ore
Subject: Re: pictures...
Date: Fri, 31 Mar 2006 11:38:11 -0500
Thanks, Sid.
Lynn
> Lynn,
> Sid
Rex Hefferan
PostPosted: Fri Mar 31, 2006 9:12 am    Post subject: pictures... Reply with quote
Lynn,
If Sid's tip doesn't work for you try this. You mentioned using
Photoshop. Save a copy of the picture with a different name. Open the
new file in Photoshop. Check the Actual pixels display size in the View
menu and use the Image menu to adjust the size using "Image size". Once
you have the actual pixel size fitted on the screen for full viewing
look for "Save for Web" in the File menu. That will optimize the image
for web use. You can't do much better than that, but sometimes using the
Filter menu with Sharpen can improve the resulting image a little. Good
Luck. Contact me off list if you have any other questions.
Rex
Colorado
Sid Hausding wrote:
Lynn,
Sid
Lynn
Rex
N740GP - M2/582
Colorado
Lynn Matteson
PostPosted: Sat Apr 01, 2006 5:01 pm    Post subject: pictures... Reply with quote
Thanks for the tip, Rex....I got the size down with "image size" but
under File in the menu, "save for web" is not highlighted...it is
dimmed. I will off-list you if I can't figure it out.
Lynn
On Friday, March 31, 2006, at 12:10 PM, Rex wrote:
Lynn,
the
Rex
Colorado
Lynn
N369LM
