cookflys
Posted: Wed May 20, 2009 5:54 am Post subject: bushing for rudder |
I removed my rudder (Model ll) for a little maint. and when I got ready to re-install I noticed one of the bushings missing. l Has anybody bought or made any of these?
Charles Cook
N363KF 582
ATL
_________________ Charles Cook
Model II 582
#363 |
akflyer
Posted: Wed May 20, 2009 9:51 am Post subject: Re: bushing for rudder |
you can pic the tubing up at most any hardware store. It is just the tubing used for running water to the ice maker in your fridge. If the OD is too large, you can put a small section in a drill spin it up and hit it with a file or sand paper to turn it down to the desired OD. Same with ID if you cant find the right diameter, just run a bit through it. I ordered 20' of new bushing material from Airdale and had to turn both the ID and OD. only took a few minutes to make it happen.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
