		cpayne(at)joimail.com Guest
				 Posted: Tue May 26, 2009 5:11 am    Post subject: Spark Plug Wire |
				Just a reminder that only Racing Wire is recommended for the "automotive" plug conversion. Passenger car wire has a resistive core intended to suppress RF and IMF emissions. This wire is designed for high voltage systems. racing wire uses a tightly wrapped shield of stainless steel wire around a copper core to provide suppression. This is the type of wire to use with our magneto systems. It offers lower electrical resistance but is more expensive.
 Either the Taylor wire that Dennis offers or Magnecore is good. Diameters over 6.5mm must have the outer sheath tapered to fit into the distributor cap.
 Regarding the spark plugs, what we are using are types designed for motorcycles and recreational equipment. I use the NGK brand because of the choices in heat ranges, and cheap price. I use the 1/2" reach but has anyone experimented th more expensive fine wire types that have a broad heat rage??
 Craig Payne
				 Posted: Tue May 26, 2009 5:42 am    Post subject: Spark Plug Wire |
				No tapering of the wires required anymore Craig as I now  provide an appropriate size drill bit in the kit to enable the installer to  drill out the magneto cap holes.  This allows the 8 mm wires to fit  neatly and snugly into the holes and more importantly, prevents the end of the  wire from "rolling" or "moving" in the hole when the small piercing screw is  screwed down into the end of the 8 mm wire.  This assures proper contact  with the center core.
  I also provide NGK plugs in the kit now because they are  easier for the customer to acquire locally at an auto parts store than the  Champion plugs were.
  Dennis
  [quote]   ---
