		sgyak18t(at)bigpond.com Guest
				 Posted: Mon May 25, 2009 2:38 pm    Post subject: YAK 18 T with vibration |
				My 18 I understand had similar problems, until Denis and his magic ignition
 system was installed. At the risk of offending the gods, my 18 purrs under
 all conditions, our temperatures get down to about -5 and up as far as 35
 centigrade. She has never turned a hair under any circumstances, the colder
 it is the better she likes it. I spend a lot of time flying over Bass
 Strait, loads of open water and when not overwater climb over mountains. The
 only place that is flat is where we land. I cannot recommend Dennis's system
 enough and the automotive champion plugs are cheap as chips
 Cheers SG
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		yakplt(at)yahoo.com Guest
				 Posted: Mon May 25, 2009 4:50 pm    Post subject: YAK 18 T with vibration |
				I have put Dennis Savarese's automotive plug and ignition wire kit in not only my own aircraft but have worked with and helped install it in 5 other M-14 equipped aircraft, some of them highly modified airshow engines.  The list of well known names that use it is off the chart.  IAC Unlimited competitors, Airshow pilots, and just "good ole boys".  It is without a shadow of a doubt the very best modification I have ever seen made on this engine, using price for performance as the determining factor.  I went for years and failed to put it on my own aircraft because I never "got a round-2-it".  Stupid.  Once I put it in I cursed myself for not doing it sooner.  What more can anyone say?  Failing to take the time to put this kit in is a mistake.  It  is the BEST $400 or so dollars that I have ever spent on my aircraft.  Period.
  Mark Bitterlich
 To: yak-list(at)matronics.com
 Sent: Monday, May 25, 2009 6:37:36 PM
 Subject: YAK 18 T with vibration
 --> Yak-List message posted by: "SRGraham" <sgyak18t(at)bigpond.com (sgyak18t(at)bigpond.com)>
 Cheers SG
