tomflysalot
Posted: Fri May 15, 2009 7:46 am Post subject: IO-540 Available |
Guys & Gals,
I have a beautiful IO-540 that has 100 smoh & 800 snew (new cylinders,
9.5:1 pistons, & crankshaft). This engine was removed from a Lancair,
has 260+ HP and runs very smooth. It has two new alternators, prop
governor, oil cooler, starter, and mags. Warranty. I have pics.
It needs a home in an RV-10.
Tom Lawson
970-420-1798
Compete with the big boys. Click here to find products to benefit your business.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTI97wbFvxKUy6Xc96f8HQkjej3raEo40wd4VbZF2uJoOxeixDypeY/
rv(at)thelefflers.com Guest
Posted: Wed May 20, 2009 11:24 am Post subject: IO-540 Available |
"It has two new alternators, prop governor, oil cooler, starter, and mags."
Who are the vendors and models for these accessories?
Also, whose exhaust is mounted?
What is the warranty and from whom?
bob
Posted: Wed May 20, 2009 11:49 am Post subject: IO-540 Available |
Sorry about the noise, I meant to send this privately.
tomflysalot
Posted: Wed May 20, 2009 12:17 pm Post subject: IO-540 Available |
No problem. The alternators are BnC, mags are Slick, the pg is set for a
Hartzell prop. I'll have to check tomorrow on the oil cooler and
exhaust.
The New Firewall Forward had the Workmanship warranty for the inpection.
Cylinders "may" be covered by Lycoming.
I'll find out more tomorrow.
Tom
On Wed, 20 May 2009 15:51:58 -0400 "Bob Leffler" <rv(at)thelefflers.com>
writes:
jaycwik(at)gmail.com Guest
Posted: Fri May 22, 2009 8:42 am Post subject: IO-540 Available |
Tom
Thanks for calling this morning
This link will take you to an article about sump and engine mount clearance with the RV-10. There is also a link embeddedhttp://www.aviationstop.com/2009/01/lycoming-oil-sump-clearance-on-rv-10.html in the article that takes you to a related Van's service bulletin. Unfortunately they don't provide specific dimensions, just that the dimensions that relate to the engine that Van's sells will work.
Thanks - Jay
On Wed, May 20, 2009 at 3:13 PM, <tom.on.the.road(at)juno.com (tom.on.the.road(at)juno.com)> wrote:
[quote] --> RV10-List message posted by: tom.on.the.road(at)juno.com (tom.on.the.road(at)juno.com)
exhaust.
Tom
On Wed, 20 May 2009 15:51:58 -0400 "Bob Leffler" <rv(at)thelefflers.com (rv(at)thelefflers.com)>
writes:
> --> RV10-List message posted by: "Bob Leffler" <rv(at)thelefflers.com (rv(at)thelefflers.com)>
