tc1917(at)bellsouth.net Guest
Posted: Sun May 24, 2009 2:38 am Post subject: rivets |
sorry about the name change, meant the same person, just had the wrong
handle on it. (age thing). Sorry Dondi -- you are nicer than Dolly anyway.
Actually, now that you mention alum. rivets -- according to an aviation mech
for the Navy, Yes, we SHOULD be using alum rivets. I dont think you want to
either pay for or pull these rivets though. I think they are called cherry
max or something like that. Steel rivets of good quality should do the
trick. Hinges and such are still the same thing, light weight alum tube
either way. The new tubes for most all the planes out there, other than the
five rib firestar, are all a thicker quality and might quite easily take the
SS rivets. My remarks were zeroed in on the five rib, light weight original
firestar and any others with the thin walled tubing.
Hope this clearifies this. ted
rowedenny
Posted: Sun May 24, 2009 3:40 am Post subject: rivets |
Just to make sure everyone is clear on this, under NO circumstance should
you use plain aluminum pop rivets in the construction of a Kolb aircraft.
Good quality steel or stainless steel pop rivets only.
Aluminum pop rivets of the downspout type are nowhere near strong enough for
aircraft use.
Denny Rowe
anyway.
mech
to
the
the
original
Posted: Sun May 24, 2009 5:51 am Post subject: rivets |
Thanks for the reply Ted C and Denny C
Like I said C I purchased the SS rivets for attaching my ailerons and flaps. I planned on using these C but got the impression Ted was saying aluminum ones would be better. I will continue with "Plan A" and use the SS rivets.
Thanks again C Mike Welch
[quote] Just to make sure everyone is clear on this C under NO circumstance should
aircraft use.
Denny Rowe
Insert movie times and more without leaving Hotmail®. See how.
Posted: Sun May 24, 2009 6:45 am Post subject: rivets |
some interesting info:
http://www.zenithair.com/kit-data/ht-87-1.html
scroll to the page bottom for his flush rivet mod
BB
On 24, May 2009, at 9:45 AM, Mike Welch wrote:
| Quote: | Thanks for the reply Ted, and Denny,
Like I said, I purchased the SS rivets for attaching my ailerons and flaps. I planned on using these, but got the impression Ted was saying aluminum ones would be better. I will continue with "Plan A" and use the SS rivets.
Thanks again, Mike Welch
| Quote: | Just to make sure everyone is clear on this, under NO circumstance should
aircraft use.
Denny Rowe
Insert movie times and more without leaving Hotmail®. See how. | Quote: | http://www.matronics.com/Navigator?Kolb-List
lcottrell
Posted: Sun May 24, 2009 7:42 am Post subject: rivets |
After 2,933.7 hours on my mkIII, it still has all its SS rivets.
Built the US in 1984, with carbon steel. Some of them rusted. When I got ready to build the FS in 1986, Kolb was still shipping carbon steel rivets with their kits. Little Mike got me SS rivets for my FS. Soon after, kits were shipped with SS rivets.
Never had a problem with corrosion between the SS rivets and aluminum.
Was true, the US and original FS were shipped with .028" 6061 leading and trailing edge tubes, and 5/16" rib tubes. Later kits had .032" tubing. Not a whole lot of difference when you get right down to the nitty gritty.
Takes a really crude craftsman to screw up construction of a Kolb kit, but I guess there are of few of those out there.
Rock House, OR
