dalemed
Posted: Fri May 29, 2009 6:57 am Post subject: 601 wing on 650 fuselage |
I'd already started my 601xl wings when the 650 design was released. I was told at that time (by the factory) that I could use the 601 wings "as is". Now I'm hearing about attachment differences between the two. Can anyone explain whats really going on and what I might need to rework on the wings?
Thanks for any enlightenment!
_________________ Dale
Zenith Zodiac CH650 |
lwinger
Posted: Fri May 29, 2009 7:26 am Post subject: 601 wing on 650 fuselage |
No reworking of the wings is required. The change in angle of incidence affects how you set the center spar in the fuselage as well as the vertical location of the rear attach plate. Because it is closer to the lower longeron, it cannot be as wide as on the 601XL, therefore it is made of thicker material.
Larry Winger
601XL (now 650) / Corvair
Ready for canopy
On Fri, May 29, 2009 at 7:57 AM, dalemed <dalemed(at)gmail.com (dalemed(at)gmail.com)> wrote:
[quote]--> Zenith601-List message posted by: "dalemed" <dalemed(at)gmail.com (dalemed(at)gmail.com)>
Dale
Flying Cessna 170B
Building Zenith CH650
http://forums.matronics.com/viewtopic.php?p=245890#245890
s List Un/Subscription,
www.matronics.com/Navigator?Zenith601-List" target="_blank">http://www.matronics.com/Navigator?Zenith601-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
bryanmmartin
Posted: Fri May 29, 2009 7:58 am Post subject: 601 wing on 650 fuselage |
I believe the 650 wings are set at a slightly different angle of
incidence to the fuselage: the trailing edge is lower. To make the 601
wings fit, all you should need to do is to adjust the lower flanges of
the center spar section to the new angle and use the new, thicker rear
attach plate.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
dalemed
Posted: Sat May 30, 2009 9:29 am Post subject: Re: 601 wing on 650 fuselage |
I think most of my confusion resulted from confusing the rear attach plate with the root doubler (6w7-2). The root doubler is also 0.063 on the 601 wing.
I'm much less confused now. Thanks for the insights!
