Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
Thom Riddle
Joined: 10 Jan 2006 Posts: 1580 Location: Buffalo, NY, USA (9G0)
Posted: Thu Aug 02, 2007 10:52 am Post subject: Tires for Allegro |
In the nearly two years we've had our Allegro, we've had about 7 or 8 flat tires, some from punctures from cotter pins, safety wire etc. but also two outright tire failures. I was on the verge of replacing them all with 600-6 6-ply aircraft tires instead of these junk wheel barrow tires that they put on at the factory. Unfortunately, the 600-6 standard aircraft tires will not fit in the wheel pants.
The good news, MAYBE, is that I found 400-6 6 ply Aero Classic Tires from Desser.com and ordered three today. I'm reasonably certain they will fit the pants and since they are deep tread aircraft tires with 6-ply construction they should last a long time on the Allegro. They are tubeless tires so I also ordered three tubes since the split hub wheels on our airplanes won't hold air.
I'll let you know how they work out.
400-6 6 PLY AERO CLASSIC LSA TIRE TUBELESS
Unit Price In Shopping Cart
43.95
Our New Light Sport Tire, 400-6 6 Ply with a Deep Aircraft Type Tread
| | - The Matronics Allegro-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Allegro-List |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
ledson
Posted: Wed May 27, 2009 1:39 pm Post subject: Re: Tires for Allegro |
THom,
You never reported on how the 400 X 6 6 ply tires worked for you. Would you please let me know how they did?
Larry
brad(at)vision-technology Guest
Posted: Wed May 27, 2009 2:01 pm Post subject: Tires for Allegro |
Hi Larry,
I'm the new owner of Thom's plane. I'm not sure if both mains were replaced at the same time, but one side is in great shape, while the other side has a serious bald spot with threads starting to show. Since the Allegro doesn't have individual brakes maybe that's due to an out of balance tire always being landed on the same spot. I seem to recall Thom mentioning some challenges with getting the tires balanced (at least the nose wheel) and my A&P says he has found the cheaper tires to be tougher to balance.
I just ordered a replacement. Aero classic 4x6 6-ply from Desser for about $45.
Brad Kramer
N221FA
Bismarck ND
--> Allegro-List message posted by: "ledson" <ledson(at)oneil.com>
THom,
Larry
http://forums.matronics.com/viewtopic.php?p=245621#245621
http://www.matronics.com/Navigator?Allegro-Listonics.com/" target=_blank>http://forums.matronics.comef="http://www.matronics.com/contribution" target=_blank>http://www.matronics.com/contribution
[quote] [b]
jlhazen(at)copper.net Guest
Posted: Wed May 27, 2009 2:44 pm Post subject: Tires for Allegro |
After my 3rd flat tire, I replaced both the main "wheelbarrow" tires on my Allegro with the 400 x 6 6ply tires from Desser. This was in September 08. I have been very happy with these tires. They fit the wheel pants just fine. It nice to have real tires since I do a lot of cross country flying and had flats in KLM, HLN and LXT. In each case I had to RON while the A&P went to town to get another wheelbarrow tire. A new set of Aero Classic tires is way cheaper than having tires replaced away from home and spending a night in a hotel.
Jim Hazen
N44469
--- ledson(at)oneil.com wrote:
To: allegro-list(at)matronics.com
Subject: Re: Tires for Allegro
Date: Wed, 27 May 2009 14:39:14 -0700
THom,
Larry
http://forums.matronics.com/viewtopic.php?p 45621#245621
ledson
Posted: Thu May 28, 2009 4:36 am Post subject: Re: Tires for Allegro |
Brad & Jim,
Thanks for the update on the tires. Mine has the OEM tires and after 100 hours of operation the right main tire shows a lot of wear on the inside of the tread. the other two seem to be holding up fine. I'm wondering if there may be some sort of an alignment issue with the aircraft. Have either of you noticed any abnormal wear that may indicate some sort of a problem in the alignment?
Larry Edson
N4362C
Posted: Thu May 28, 2009 8:35 pm Post subject: Tires for Allegro |
I haven't noticed any wear that'd indicate a gear alignment problem on mine.
Have you tried just using a large carpenters square to compare the camber (i.e. tilt) of the left & right wheels? That'd be a quick & easy check as a starting point.
I don't recall what, if any, alignment adjustments can be made on the Allegro. Of course there's always the option to just rotate the tires every 25 hours or so if a better alignment isn't possible.
One other interesting possibility is that you often touch down first on the right side tire. Most pilots, including me, tend to touch down with the left wheel first. My mechanic swears that he replaces a lot more left tires than right ones. Mention that piece of trivia the next time you're hanging out with a bunch of pilots and see what happens. (then go on to discuss downwind turns) ... but I digress...
...Brad
N221FA
Brad & Jim,
Larry Edson
N4362C
http://forums.matronics.com/viewtopic.php?p=245675#245675
