Don McIntosh
Joined: 02 Jul 2007 Posts: 21 Location: Sandpoint, Idaho
Posted: Fri May 29, 2009 9:58 am Post subject: Stereo to Mono |
I want to install a plug in my panel to plug my stereo Walkman into but my intercom (PM1000 II) is mono. Can I just splice the Right and Left leads together to go into the intercom? Also the intercom pins are labeled "HI" and "LOW". Is this just the pin identification numbers?
_________________ Don McIntosh
Kitfox Series 7
Jabiru 3300 |
Posted: Fri May 29, 2009 10:34 am Post subject: Stereo to Mono |
At 12:58 PM 5/29/2009, you wrote:
<don(at)contractorsnorthwest.com>
Put a 100 ohm, 1/4w resistor in series with the two
stereo output before bringing them together at the
"HI" input terminal. The "LOW" terminal is ground.
( -Thomas Paine 1776- )
Don McIntosh
Posted: Fri May 29, 2009 2:08 pm Post subject: Re: Stereo to Mono |
Bob,
Thanks for the answer. OK, so behind the panel, where do you mount these resistors, or are they just soldered in-line with heat shrink over them?BTW I am in process of reading your book.
Kitfox Series 7
Jabiru 3300 |
Posted: Fri May 29, 2009 2:56 pm Post subject: Stereo to Mono |
At 05:08 PM 5/29/2009, you wrote:
Bob,
Given the relatively low priority for
comfortable terminaion of flight, I think
I'd build them into the wire bundle and
heat shrink 'em. See:
http://aeroelectric.com/articles/Homeless/Homeless_Components.htm
| Quote: | BTW I am in process of reading your book.
Great! If you have any questions, post them
here on the List.
raymondj(at)frontiernet.n Guest
Posted: Fri May 29, 2009 3:25 pm Post subject: Stereo to Mono |
Bob,
Just a quick question. It the resistor to lower the voltage at the
intercom or is it related to what the CD player output sees? Or
something completely different. If it is to lower the voltage, should
the voltage be in the same range as the other inputs to the intercom?
Raymond Julian
Kettle River, MN.
"Hope for the best, but plan for the worst"
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
Posted: Fri May 29, 2009 7:19 pm Post subject: Stereo to Mono |
At 06:24 PM 5/29/2009, you wrote:
Bob,
voltage at the intercom or is it related to what the CD player
output sees? Or something completely different. If it is to lower
the voltage, should the voltage be in the same range as the other
The resistors are a crude "audio mixer" that
gives you a mono-average of right and
left channels. It also isolates the right
and left audio amplifiers from each other so
that diverse audio signal levels in the
two channels don't cause the two amplifiers
to arm-wrestle.
The resistors can be lower . . . say the
same as for MP3 player headphones . . .
33 ohms. But you probably won't hear much
loss of signal that cannot be compensated
for by turning up the volume on the audio
device.
bakerocb
Posted: Sat May 30, 2009 4:20 am Post subject: Stereo to Mono |
5/30/2009
Hello Don, You wrote: "I want to install a plug in my panel to plug my
stereo Walkman into but my intercom (PM1000 II) is mono."
Here is one way to solve that problem --
http://www.radioshack.com/product/index.jsp?productId 102669
This adapter will put the output of a mono jack on your panel into both
sides of your stereo Walkman.
Also take a look at some of the other adapters available. You may want to
put a normal airplane earphone sized jack on your instrument panel so that
either your Walkman (with an adapter) or an airplane earphone set (without
adapter) may be plugged in.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Subject: Stereo to Mono
From: "Don McIntosh" <don(at)contractorsnorthwest.com>
intercom
Is
Don McIntosh
Kitfox Series 7 under construction
Jabiru 3300
gmcjetpilot
Posted: Mon Jun 01, 2009 2:07 am Post subject: Stereo to Mono |
I would not use a stereo to mono jack to go FROM stereo to MONO. It really is made
for going from mono to drive a stereo headphone, split to drive both L & R channels.
It is not designed to combine stereo to mono.
Whats the big deal? Shorting L & R of an amp can cause damage, even an iPod. If the
"Walkman" has a mono switch than its OK, but iPods do not have mono switches.
If you don't have a MP3 player (iPod) get one. Walkman are last decades news. If you
don't have an iPod you can get 100's of hours of music on them with play time of 6 hours
per charge. They are also small and light weight.
There are some threads on how to properly combine stereo and ground issues in this
forum. Just use the search engine. The easy way is with capacitor and resistor, which
you can wire behind the panel. You would use a stereo 1/8" phone jack and then
go from stereo to mono with the isolation Cap and Resistor.
Cheers George
>From: <bakerocb(at)cox.net (bakerocb(at)cox.net)>
| Quote: | Subject: Stereo to Mono
| Quote: | 5/30/2009
| Quote: | stereo Walkman into but my intercom (PM1000 II) is mono."
>http://www.radioshack.com/product/index.jsp?productId=2102669
| Quote: | sides of your stereo Walkman.
| Quote: | put a normal airplane earphone sized jack on your instrument panel so that
| Quote: | >I want to install a plug in my panel to plug my stereo Walkman into but my
| Quote: | >Don McIntosh
>Jabiru 3300
jd(at)lawsonimaging.ca Guest
Posted: Thu Jun 04, 2009 3:42 am Post subject: Stereo to Mono |
bakerocb(at)cox.net wrote:
5/30/2009
Greetings... I'm a bit confused on this subject after reading this thread and
similar threads in other lists. I have the same objective: plug my iPod into my
Xcom 760's audio in. The Xcom's documentation says to use a 3.5mm mono jack in
combination with a stereo-to-mono adapter plug. My thought was to eliminate the
adapter plug by simply jumping the left/right channel pins on the jack itself,
and this does indeed give [seemingly] good results with both channels clearly
heard. But lately I've read that this may damage the iPod, and I should be using
resistors/capacitors and/or the adaptor, as though the adaptor had some
components built into it's small, moulded little case. I'm relatively sure that
this adaptor plug is doing nothing but physically joining the left and right
channels from the stereo plug into a single tip on the mono plug, and is in no
way electronically 'magic'.
Not wanting to damage my iPod, I'd be interested to know the science behind all
the posts saying 'don't do it' (wire the left and right together), use the
adaptor plug. Thanks!
Regards, J.
Sonex C-FJNJ
| J. Davis, M.Sc. | (computer science) |
| *NIX consulting, SysAdmin | email: jd at lawsonimaging.ca |
and now... Deep Thought #39, by Jack Handy
Probably the earliest flyswatters were nothing more than some sort of
striking surface attached to the end of a long stick.
chris_hand(at)comcast.net Guest
Posted: Thu Jun 04, 2009 9:44 pm Post subject: Stereo to Mono |
<If you don't have a MP3 player (iPod) get one. Walkman are last decades news. If you
<don't have an iPod you can get 100's of hours of music on them with play time of 6 hours
<per charge. They are also small and light weight.>
Actually, I use a Sony Walkman in my RV-6A that has something on the order of 400+ songs right now with plenty of storage room to spare for more songs, videos, photos, etc. Weighs a few ounces, plugs into my intercom, didn't cost much, and works great. It's a Sony Walkman digital media player - smaller physical size than the i-pods my kids prefer and does all I want for the RV. Although once upon a time I did have one of the Walkman units you are talking about, Sony has rehashed the name with current technology.....not sure which era Don's Walkman is from.
Chris
harley(at)AgelessWings.co Guest
Posted: Fri Jun 05, 2009 5:18 am Post subject: Stereo to Mono |
>>Sony Walkman in my RV-6A that has something on the order of 400+ songs right now with plenty of storage room to spare for more songs, videos, photos, etc.<<
You mean those tapes I use in my Walkman have been replaced by something better? <VBG>
Actually I am very happy with the HP pocket computer that came with my newest upgrade to Anywhere Map. It fits in my pocket when not in it's vehicle mount, it has wireless internet (I did replace the Microsoft browser with "Opera", however), MP3 player, Bluetooth, built in GPS antenna, Tom-Tom for ground navigation, and, of course, AnywhereMap. Not to mention the games that I loaded into it that I can play while waiting in the doctor's waiting rooms! <G>
It does have an output socket for earphones and I have an adapter for the 1/8" socket to a 1/4" plug to just plug in to the appropriate socket in my intercom. But haven't gotten around to connecting it to my intercom yet, since I don't even have an electrical system in my plane yet! Hopefully before this year is out....
Harley
Chris Hand wrote: [quote] <If you don't have a MP3 player (iPod) get one. Walkman are last decades news. If you
Chris
| Quote: | ----- Original Message -----
From: gmcjetpilot(at)yahoo.com (gmcjetpilot(at)yahoo.com)
To: aeroelectric-list(at)matronics.com (aeroelectric-list(at)matronics.com) ; don(at)contractorsnorthwest.com (don(at)contractorsnorthwest.com)
Sent: Monday, June 01, 2009 3:00 AM
Subject: Re: Stereo to Mono
Cheers George
>5/30/2009
>[url=http://www.radioshack.com/product/index.jsp?productId 102669]http://www.radioshack.com/product/index.jsp?productId 102669[/url]
>>From: "Don McIntosh" <don(at)contractorsnorthwest.com (don(at)contractorsnorthwest.com)>
>>Don McIntosh
>>Jabiru 3300
| [b]
rcole927(at)earthlink.net Guest
Posted: Sat Jun 06, 2009 9:27 am Post subject: Stereo to Mono |
Does anyone know if the 1/8-inch phone jack audio output on a Garmin 396 is stereo or monaural? I plan to route this output into the monaural input of the intercom. If the Garmin output is stereo, I can do the two-resistor mixer that was mentioned previously in this thread.
Roger Cole
1946 Cessna 140, flying
Murphy Elite #709, working on fuselage
rcole927(at)earthlink.net (rcole927(at)earthlink.net)
On Jun 5, 2009, at 12:40 AM, Chris Hand wrote:
[quote]<If you don't have a MP3 player (iPod) get one. Walkman are last decades news. If you
Chris
[quote]---
JohnInReno
Posted: Sat Jun 06, 2009 12:05 pm Post subject: Stereo to Mono |
I think I have a similar problem in a spam can. There is a 1/8 plug coming out of the intercom that I can plug into a Garmin 496. The results are audible but poor. XM radio is barely audible but verbal warnings from the 496 are much clearer. Could it be that I need a 1/8 mono to stereo adapter or is additional wiring required?
Can I measure the resistance of the adapter to determine if it contains more than a solid connection?
John Morgensen
Roger Cole wrote: [quote] Does anyone know if the 1/8-inch phone jack audio output on a Garmin 396 is stereo or monaural? I plan to route this output into the monaural input of the intercom. If the Garmin output is stereo, I can do the two-resistor mixer that was mentioned previously in this thread.
Roger Cole
_________________ RV-9A - Fuselage
Grumman AA1B-150 (RV-Trainer) Flying |
mprather(at)spro.net Guest
Posted: Sat Jun 06, 2009 7:51 pm Post subject: Stereo to Mono |
The Garmin 396 owner's manual makes reference to connecting stereo
headphones to the audio jack on the 396 (p114). I plug my 396 into my car
stereo's aux port all the time. I'm pretty sure I get stereo signals from
it.
Matt-
| Quote: | I think I have a similar problem in a spam can. There is a 1/8 plug
John Morgensen
> Roger Cole
> rcole927(at)earthlink.net <mailto:rcole927(at)earthlink.net>
