andrewbutler(at)ireland.c Guest
Posted: Thu May 28, 2009 4:54 am Post subject: 12V Power Socket |
Hello,
I am wiring up a 12V (cigarette lighter) power socket into my panel.
Can anyone tell me the convention for the +ve and -terminals on these things?
Andrew.
jay(at)horriblehyde.com Guest
Posted: Thu May 28, 2009 5:45 am Post subject: 12V Power Socket |
The positive is the centre post and negative the outer shell.
Jay
aslsa.rng(at)gmail.com Guest
Posted: Thu May 28, 2009 6:10 am Post subject: 12V Power Socket |
Positive is the center (spring loaded plunger on the plug), ground is the shell (two flat connectors along the side of the plug).
Rick
On Thu, May 28, 2009 at 7:45 AM, Andrew Butler <andrewbutler(at)ireland.com (andrewbutler(at)ireland.com)> wrote:
[quote]--> AeroElectric-List message posted by: Andrew Butler <andrewbutler(at)ireland.com (andrewbutler(at)ireland.com)>
Hello,
Andrew.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
rv9jim(at)juno.com Guest
Posted: Thu May 28, 2009 6:11 am Post subject: 12V Power Socket |
Andrew,
The usual center is positive and the shell goest to ground. You
should wire the scocket to powerthe panel with out turning the master on.
I have mine that way so I can play with the panel with out using the
aircraft battery. I have a little cpmpressor / battery unit that I take
to the hanger and keeps the tires up and lets me run my glass panel for
setting up a trip etc.
Jim
Compete with the big boys. Click here to find products to benefit your business.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTI97zF6gFxJRmQXuZsZBzUiPEnqkuoiaMthATKQtsww5EJAaYCWxa/
longg(at)pjm.com Guest
Posted: Thu May 28, 2009 6:44 am Post subject: 12V Power Socket |
Absolutely, if you think about it for just a second, these things are no different than a standard light bulb socket. Touch the center contact and you’ll light up; touch the ring and your still here. When people used to smoke everyone knew the center contact had to touch to make the heat and the cool ground was the outside. After too many cigarettes you got stinky fingers and the contact would begin to fail and loose heat thus becoming less of a conductor between the center and the shell. If the shell were a on the + side of the ship, your 63 Chevy’s steel panel would still be smoking.
Glenn
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Thursday, May 28, 2009 9:44 AM
Subject: Re: 12V Power Socket
Rick
Hello,
Andrew.
le, List Admin.
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Thu May 28, 2009 8:15 am Post subject: 12V Power Socket |
It depends on what you want to accomplish. If you wire it to the buss side
of the master you can power your panel from it during the build. But if you
wire it to the battery side of the master you can power accessories or
trickle charge the battery without turning on the master. There are pluses &
minuses both ways. Think it through and decide what's best for you.
Greg Young
[quote] --
Posted: Sat May 30, 2009 11:53 pm Post subject: 12V Power Socket |
Thanks to all for the great replies. No worries now!
Andrew.
RV7 (firewall forward and wiring)
EI-EEO (just received!)
Galway, Ireland.
