		aerosport1
				 Posted: Sat Jun 06, 2009 12:24 pm    Post subject: Door glass/windows |
				I am in the process of installing my windows in the doors and the windows are  .165 to .1875 thick and do not fit the window channel. They are almost .04 to .060 to thick. It seems that these should be the same thickness as the rear windows which were .120 to .140. Has anyone else had this issue? If I try to sand down the shelf the window sits on I will sand almost or will go through the external door skin. At this thickness
 there would be no good way to blend these into the outer door skins.
 Geoff
  _________________ Geoff Combs
 RV-10 QB N829GW
Flying 500 hrs
40033 |
		Jim Berry
				 Posted: Sat Jun 06, 2009 6:30 pm    Post subject: Re: Door glass/windows |
				Geoff,
 Other than smoothing the outer face of the window channel, I would not remove any material trying to make the outer face of the window flush with the door. Most/all of the window edge will stand proud of the door. I think most people have found more variability with the rear windows i.e. in some places the window is proud(high) and in other places the cabin top is proud. Welcome to the world of body working Van's quality fiberglass products to make it all pretty. Flox, micro and hours of sanding will bring it all to the same level(eventually).
 Jim Berry
 40482
 N15JB
		partner14
				 Posted: Mon Jun 08, 2009 1:56 pm    Post subject: Door glass/windows |
				I had one window that had the dimensions that you are talking about.... I sent it back to Van's and got a replacement.  Next window, no problem.
  Don McDonald
 --- On Sat, 6/6/09, aerosport1 <g.combs(at)aerosportmodeling.com> wrote:
 From: aerosport1 <g.combs(at)aerosportmodeling.com>
 Subject: Door glass/windows
 Date: Saturday, June 6, 2009, 1:24 PM
  --> RV10-List message posted by: "aerosport1" <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)>
 Geoff
 Geoff Combs
 RV-10 QB N829GW
 Finishing
 http://forums.matronics.com/viewtopic.php?p=247108#24710om/Navigator?RV10-List" target=_blank>http://www.matronics.com/Navigator?              - MATRONICS WEB FORUM;               -Matt Dralle, List Admin==========
40636 |
		aerosport1
				 Posted: Mon Jun 08, 2009 2:11 pm    Post subject: Door glass/windows |
				Thanks  for everyone's input.
  FYI
  I did  talk to Scott today at Van's and he gave me the specs for the door windows and  mine are way to big. They are sending me some new ones out  tomorrow.
  Scott  said they should be .120 to .150. That was there specifications. The .150 was on  the very high side and could be to thick depending on the door  frame.
  Geoff
   Geoff  Combs
  President
 Aerosport Modeling &  Design
 8090 Howe Industrial Parkway
 Canal Winchester, Ohio  43110
  614-834-5227p
 614-834-5230f
  www.aerosportmodeling.com
 RV-10 QB N829GW
Flying 500 hrs
40033 |
