Help with LCD Circuit Design - Altitude & Heading
etienne.phillips(at)gmail
PostPosted: Thu Jun 11, 2009 10:16 am    Post subject: Help with LCD Circuit Design - Altitude & Heading Reply with quote
If I were looking at a similar project, I would consider using a
microprocessor, 7-segment LED displays (or a backlit LCD for good
sunlight readability), and two quadrature jogdials. It's not a simple
solution though, and I'd be hesitant to encourage you to attempt this
solution as a novice due to the combined software and hardware nature
of the microprocessor...
Total electronics cost (assuming you have all the required tools and
a programmer) in the order of $15, then you'll need an enclosure of
some sort. Maybe another $15-$20. Certainly do-able for waaaaay less
than $400.
Hope this inspires some other answers, hopefully with a simpler
solution that would make a good project for a beginner Smile
Etienne
Very simple from a hardware perspective, and the code for the
microprocessor is not too hard. However, I'm not a noob (BSc in
Electrical Engineering Wink ), and I have all the required tools on hand!
On 11 Jun 2009, at 7:06 PM, mikef wrote:
Hi,
I am interested in building a simple, small, bright LCD display
that can increment numbers with the twist of a knob. I would like
to build a 4 digit and 3 digit versions, to represent pattern
altitude and heading, respectively. Put it in a small enclosure and
mount on my dash.
Pattern altitude - knob changes in 100' increments
Heading - knob changes in 10 degree increments. Would be nice to go
from 0 to 360, then roll back over to zero (0).
I know you knowledgeable electronics guys are thinking this is
stone simple, but.... I'm a noob. I don't know which parts to mix
and match to make this happen. And while having googled lots of
stuff, I am still unsure how to pick the right parts to make this
work. So if someone in the know could suggest the right combination
of parts it would be most appreciated.
Here is a commercial version that inspired my request here. But
sweet jeeezus, at $400 that is just plain outrageous for what I bet
cost maybe $50.
http://www.p2inc.com/skybuddy.asp
Thanks in advance!
Mike
http://forums.matronics.com/viewtopic.php?p 47702#247702
mikefapex
PostPosted: Thu Jun 11, 2009 1:15 pm    Post subject: Re: Help with LCD Circuit Design - Altitude & Heading Reply with quote
Etienne,
Thanks for your note. It is educational. I'll keep the info in mind.
Mike
