		frank.goodnight(at)att.ne Guest
				 Posted: Fri Jun 12, 2009 5:12 am    Post subject: Flat tire {none event?} |
				A couple of  weeks ago I was chugging along about an hour from the
 airport and about 500 ft.
 feeling really pleased with myself , thinking - what a great day. then
 I happened to look at
 my left tire. It looked strange, in the firestar I can touch the tires
 if I relax the sholder straps a
 little.when i felt of it -PANIC- low time pilot, andnot much of it in
 a kolb. WHATS GOING TO HAPPEN? An hour and a half latter when I HAD to
 land , I did the very best full stall , tail wheel
 first landing that I was capable of, there was NO difference from a
 normal landing untill I
 slowed to just above walking speed. Then the A/C just stopped moveing
 no matter how
 much power. I had to get out and pull it off the runway by hand. Can
 some of you older pilots
 tell me if this is normal , or was I just lucky? What is the best way
 to land a kolb with a flat?
 Frank Goodnight
 firestar 2
 75 hrs
 Brownsville TX.
				 Posted: Fri Jun 12, 2009 6:23 am    Post subject: Flat tire {none event?} |
				Can
  	  | Quote: | 	 		   some of you older pilots
  tell me if this is normal , or was I just lucky? What is the best way  to
  Frank Goodnight
 Jim Swann is a lot older than me, and a FS pilot.
 Never tried to land with a flat tire.
 I think you did it one satisfactory way.  You made it down and did not bend
 the airplane.
 I have landed my Ultrastar with one main gear involuntarily retracted.  Got
 a wing tip, but that is the nature of the US.  Landed my buddy's US after a
 3/16 bolt sheared on one end of the main gear braces.  Got his wing tip too.
  _________________ John Hauck
Titus, Alabama |
		Dana
				 Posted: Fri Jun 12, 2009 9:16 am    Post subject: Flat tire {none event?} |
				At 09:01 AM 6/12/2009, frank.goodnight wrote:
  	  | Quote: | 	 		  ...the A/C just stopped moveing
 no matter how
 I don't know if my tire was flat the other day when I landed; I realized it
 was flat when it took a LOT of power to taxi after landing!
 That was the call to put a tube in the tire; I had been procrastinating.
 -Dana
   The most useful tool for dealing with management types is, of course, an
 automatic weapon.
		Possums
				 Posted: Fri Jun 12, 2009 1:22 pm    Post subject: Flat tire {none event?} |
				At 09:01 AM 6/12/2009, you wrote:
   	  | Quote: | 	 		  slowed to just above walking speed. Then the A/C just stopped moveing
  no matter how
  Frank Goodnight |
  I've landed with flats before. Not nearly as bad as you might think, like having the brakes
  on is all.
  Taking off with a flat is a lot harder to do, but you can do it if
  you have to, at least in a Firestar. If you've got nothing else, try stuffing your shirt or
  something in the flat tire to get off the ground. Of course if you have a choice,
  don't do it.
  Landing without a tail wheel spring is not something you want to do. It gets real
  squirrely as soon as the tail wheel touches down.
  _________________ Possum |
