MChase(at)gdatp.com Guest
Posted: Thu Jun 18, 2009 3:26 am Post subject: Rivet Plates |
Guys,
OK this may be a bit late to ask this question but I took a bit of time off from my wings and seem to have forgotten how to do rivet plates.
When I attempt to rivet the plate on I am having issues with a gap between the surface and plate due to rocking on the dimple put in for the screw down the middle. Trying to get in there with a pair of needle nose pliers to hold everything tight is a bit more then I can do with 2 hands:-)
Michael Chase
Sr. Manager Supplier Quality
General Dynamics Armament and Technical Products, Inc
128 Lakeside Ave
Burlington, VT 05401
802.657.6029 Office
802.922.5930 Cell
802.657.6715
mchase(at)gdatp.com
This e-mail message (including attachments, if any) is for the sole use of the intended recipient(s) and may contain information that is private, confidential, or exempt from disclosure. Any unauthorized review, use, copying, printing, disclosure, retention, or distribution is strictly prohibited. If you are not the intended recipient, please contact the sender by reply to this e-mail, and delete all copies without disclosing this message to others. Thank you.
Lew Gallagher
Posted: Thu Jun 18, 2009 3:42 am Post subject: Rivet Plates |
Hey Michael,
If there's a dimple for the screw, you should be using a nut plate that is countersunk for the dimple ... ?
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
ricksked(at)embarqmail.co Guest
Posted: Thu Jun 18, 2009 3:57 am Post subject: Rivet Plates |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> Dumb as it may sound...you are using the 1100 style nutplates? And you are dimpling the lugs? I just use a cleco to hold one side while riveting the other side...never had and problems with rocking of the plate...that's all I can think of Michael..Rick SkedN246RS
Sent via BlackBerry by AT&T
Date: Thu, 18 Jun 2009 07:20:12 -0400
Subject: RV10-List: Rivet Plates
Guys,
Michael Chase
128 Lakeside Ave
802.657.6029 Office
802.922.5930 Cell
802.657.6715
mchase(at)gdatp.com
| Quote: | | _-============================================================ _-= - The RV10-List Email Forum - _-= Use the Matronics List Features Navigator to browse _-= the many List utilities such as List Un/Subscription, _-= Archive Search & Download, 7-Day Browse, Chat, FAQ, _-= Photoshare, and much much more: _-= _-= --> http://www.matronics.com/Navigator?RV10-List _-= _-============================================================ _-= - MATRONICS WEB FORUMS - _-= Same great content also available via the Web Forums! _-= _-= --> http://forums.matronics.com _-= _-============================================================ _-= - List Contribution Web Site - _-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-= --> http://www.matronics.com/contribution _-============================================================ |
ogdenk
Posted: Thu Jun 18, 2009 4:37 am Post subject: Rivet Plates |
Michael,
If I recall some of the numbers, there is for example a K1100-6 and a K1100-06 nutplate for #6 screws, one is for dimpled skins, the other is flush. Are you sure you are using the right nutplate? It's easy to confuse some of these part numbers.
Kent Ogden
| Quote: | >> Michael D Chase <MChase(at)gdatp.com> 6/18/2009 7:20 AM >>>
Guys,
Michael Chase
128 Lakeside Ave
802.657.6029 Office
802.922.5930 Cell
802.657.6715
mchase(at)gdatp.com
bcondrey
Posted: Thu Jun 18, 2009 6:21 am Post subject: Rivet Plates |
It’s actually K1000 series for flush and K1100 series dimpled skins, the suffix is the screw/bolt size. More than once when building I just glanced at the plans, misread, and grabbed a 1000 when I should have grabbed an 1100.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kent Ogden
Sent: Thursday, June 18, 2009 7:31 AM
Subject: Re: Rivet Plates
Michael,
Kent Ogden
Guys,
Michael Chase
128 Lakeside Ave
802.657.6029 Office
802.922.5930 Cell
802.657.6715
mchase(at)gdatp.com
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
~'k{w/ [quote][b]
Albert Gardner
Posted: Thu Jun 18, 2009 8:43 am Post subject: Rivet Plates |
There is also a nutplate that has dimpled holes for the attaching rivets.
You can dimple those holes yourself however. I don't know the part no.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Bob Turner
Posted: Thu Jun 18, 2009 9:13 am Post subject: Re: Rivet Plates |
Just to summarize:
If the hole for the screw is dimpled, you need K1100-xxx series. If the screw hole is not dimpled, you need K1000-xxx series.
If the nutplate attaching rivets are in a dimpled skin, you will need to dimple the attaching holes in the nutplate. Most dimple dies will hit the center, threaded portion of the nutplate. You'll need to grind down the female die slightly, or build a jig (which is what I did) to avoid damaging the center, threaded part.
_________________ Bob Turner
RV-10 QB |
