Need some RV tire/tube advice
Randy.McFarland(at)novell
PostPosted: Mon Jun 15, 2009 3:40 pm    Post subject: Need some RV tire/tube advice Reply with quote
Changing tires on my 7A after 310 hours. Considering McCreary Air Hawks thru A/C Spruce. BUT, tubes appear to cost $52 each! If tubes have been otherwise good and reliable, what should their service life be? Same as tire or ???
Thx
Randy
7A San Martin, Ca
pitts_pilot(at)bellsouth.
PostPosted: Mon Jun 15, 2009 4:55 pm    Post subject: Need some RV tire/tube advice Reply with quote
Randy, I'm getting ready to change the tubes in my Pitts. They're 28
years old, and have been through 4 or 5 sets of tires. The
recommendations (probably from those that sell tubes!) is to change
tubes with tires. I don't know anybody who does that. I've seen more
tubes damaged from improper installation than old age.
Linn
tire or ???
Thx
Randy
7A San Martin, Ca
Checked by AVG - www.avg.com
jsflyrv(at)verizon.net
PostPosted: Mon Jun 15, 2009 5:36 pm    Post subject: Need some RV tire/tube advice Reply with quote
Have you tried
http://www.desser.com/tires.shtml
they sometimes have good deals and combo prices. I have had excellent
service from them.
Thx
Randy
7A San Martin, Ca
yenduc(at)sbcglobal.net
PostPosted: Mon Jun 15, 2009 6:11 pm    Post subject: Need some RV tire/tube advice Reply with quote
If you do decide to change tubes I recommend the michelin airstops -- http://www.aircraftspruce.com/catalog/lgpages/michAviator2.php. They are s bit more expensive -- but worth it from the standpoint of not having to add air as often. I'm on my second se tof tires with them on my Cherokee and I put them on my RV 7A.
Dave
Thx
Randy
7A San Martin, Ca
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
mcculleyja(at)starpower.n
PostPosted: Mon Jun 15, 2009 6:29 pm    Post subject: Need some RV tire/tube advice Reply with quote
I can highly recommend the Michelin Condors. I have well over 500 hours
on a pair with 2/3 of the original tread depth yet to go and all on hard
surface operation.
Jim McCulley
tire or ???
Thx
Randy
7A San Martin, Ca
Vanremog(at)aol.com
PostPosted: Mon Jun 15, 2009 7:29 pm    Post subject: Need some RV tire/tube advice Reply with quote
Try the Condor tires and, as long as you are now getting a tire that will last a lot longer than the Macs, upgrade to the Michelin Air Stop tubes. I think that you will be very happy with this combination.  It's a good value all around.
N1GV (RV-6A Flying 920TTAE Silicon Valley, CA)
In a message dated 6/15/2009 4:41:26 P.M. Pacific Daylight Time, Randy.McFarland(at)novellus.com writes:
An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps!
JohnInReno
PostPosted: Tue Jun 16, 2009 6:24 am    Post subject: Need some RV tire/tube advice Reply with quote
Slightly off topic, but has anyone used the "accu-pressure" valve type gauges on hard to reach tires?
John
Thx
Randy
7A San Martin, Ca
Mcculley wrote: [quote]--> RV-List message posted by: "J. Mcculley" <mcculleyja(at)starpower.net> (mcculleyja(at)starpower.net)
I can highly recommend the Michelin Condors. I have well over 500 hours on a pair with 2/3 of the original tread depth yet to go and all on hard surface operation.
Jim McCulley
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
mark(at)macomb.com
PostPosted: Tue Jun 16, 2009 10:12 am    Post subject: Need some RV tire/tube advice Reply with quote
I had a similar experience Linn. Our Cherokee's front tire started
losing air so I replaced the tire and tube. The plane had been flown
mainly off of grass and we couldn't remember replacing that tire in 30
years. Logbooks didn't tell us otherwise. Reuse the tube till it won't
hold air any more.
Mark
Linn
> Thx
> Randy
> 7A San Martin, Ca
Gary.A.Sobek
PostPosted: Tue Jun 16, 2009 12:26 pm    Post subject: Need some RV tire/tube advice Reply with quote
Randy:
Once you get GOOD Michelin "Airstop" tubes (or equivalent) C they will last a long time and you can forget about changing tubes till you get a leak. (Based on my experience.)
For new tires C the Goodyear tires last the longest and the Condor 2nd longest for NEW tires.  The longest lasting tires and best tires I have had have been Goodyear retreads from Wilkerson Aircraft Tires.  http://www.wilkersonaircrafttires.com/  Paid $50 each delivered for their cores.  The Wilkerson retreads last at least 50% longer than NEW Goodyear tires and are a lot less money. They are heaver C have a better rubber C and more rubber than NEW tires.
Looks like they have a SPECIAL going on right now.  $44 for 500 - 5's.
http://www.wilkersonaircrafttires.com/genav.html
I like the Wilkerson retread tires so much C that I now am on my 2nd set. Was turned on to the Wilkerson retreads several years ago by one of my Texas Formation friends (he works in the Texas Department of Transportation C Aviation Division) when I flew as part of "Falcon Flight" maneuvering routine at GoldenWest air show.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell C
2 C231+ Flying Hours So. CA C USA
Microsoft brings you a new way to search the web. Try Bing™ now [quote][b]
tcervin(at)embarqmail.com
PostPosted: Tue Jun 16, 2009 3:30 pm    Post subject: Need some RV tire/tube advice Reply with quote
Randy,
Goodyear also makes Airstop Tubes and they are excellent! Goodyear uses Flexten belts in their tires which are 5 times stronger than steel belts. Flexten tires are also lighter and every pound counts.
Tom in Ohio
