air / fuel separator for manifold pressure gauge line?
pchap(at)primus.ca
PostPosted: Wed Jun 17, 2009 5:27 pm    Post subject: air / fuel separator for manifold pressure gauge line? Reply with quote
For anyone running a variable pitch prop, and a mechanical manifold
pressure gauge, what do you use as a fuel separator in the line from
the carb(s) to the instrument?
I've got a 912 with an Ivoprop inflight adjustable, and have a
plastic line coming off a port on the balance tube between the two carbs.
I had a little plastic gadget installed in the line but it eventually
broke, and I don't know where it was from. I tried a small fuel
filter but the MP gauge just starts filling up with fuel. I might try
to build something -- basically a tiny bottle with an in and out hose
through the lid on top would likely do. I recall someone on the list
built something like that more than a decade back.
Peter Chapman
Toronto, ON 601 HDS / 912 / C-GZDC
