No Title
naumuk(at)alltel.net
PostPosted: Sat Apr 01, 2006 5:43 pm    Post subject: No Title Reply with quote
Mike+Mike-
If you mess with them with a heat gun long enough, you won't have to use
filler. There should be about a 2 week string on the subject from me and
others last year or the year before in the archives.
1. Don't trim them until the last minute.
2. Don't expect immediate results. I had to fart around with them for
probably 4 hrs each.
3. Depending on how long it's been since you received your kit, you
might want to order new ones. They seem to set into the shape they were
shipped in after a certain amount of time.
Once again, check the archives. Good luck. Just remember, beat on the
wall or some other non-critical object rather than your project!
Bill
