nose wheel shimmy and other tire balance issue
ronlee(at)pcisys.net
PostPosted: Sat Jun 20, 2009 7:14 am    Post subject: nose wheel shimmy and other tire balance issue Reply with quote
I installed the MATCO nose wheel axle on my 8A.
Someone posted somthing similar/identical to this in the last year.
I lost the link to the item and did not see the appropriate item
in Aircraft Spruce.
Could you provide a link to the proper item?
Ron Lee
PostPosted: Sat Jun 20, 2009 7:44 am    Post subject: nose wheel shimmy and other tire balance issue Reply with quote
I think I just found it at the Matco website. Is this it:
http://www.matcomfg.com/AXLEASSEMBLYA24125INCH-idv-3657-1.html
Ron lee
carl.froehlich(at)verizon
PostPosted: Sat Jun 20, 2009 8:44 am    Post subject: nose wheel shimmy and other tire balance issue Reply with quote
That's it. The spacers are only needed for the RV-10 install.
Carl
