mshimei(at)bellsouth.net Guest
Posted: Sat Jun 27, 2009 8:49 pm Post subject: Cuyuna 430 and Pterodactyl |
Does anyone know the proper belt tension for the 4 belt drive? About how much flex in the middle in inches(or MM)
My Cuyuna turns up 5750 at T.O. and 5950 max cruise.Ultrastar climbs out at 700 FPM,cruise 5000 RPM at 50mph,CHT around 290 deg.Takes off in 80' with a little headwind on concrete.
I know it needs less pitch(has an Ultraprop 3 blade 48") but it flies great. Am I loading it down too much?
Thanks,Mark.....Ultrastar with 30hrs since March
Posted: Sun Jun 28, 2009 5:29 am Post subject: Cuyuna 430 and Pterodactyl |
The Kolb belt drive used two poly-V belts on the Ultrastar and Cuyuna ULII02. I don't know about 4 belt drives.
Kits came with a Culver 50X30 prop. This was a near perfect prop for the US. I imagine Valley Engineering is probably still carving that particular prop.
_________________ John Hauck
Titus, Alabama |
