MS3SPA on an O-200
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List
vk3eka(at)bigpond.net.au
PostPosted: Mon Jun 29, 2009 12:44 am    Post subject: MS3SPA on an O-200 Reply with quote
Hi Guys,
I am installing an O-200 on a Zenith 601XL. I am having difficulty routing
the mixture cable from the carb to the cockpit.
Presently the lever operates in such a way as to put the oil sump directly
in its way. I think I have the wrong lever on the carb. The number is
155-28. Does anybody know what part # I should have?
Cheers
Peter
Wonthaggi Australia
- The Matronics Continental-List Email Forum -
http://www.matronics.com/Navigator?Continental-List
GLJSOJ1
PostPosted: Mon Jun 29, 2009 3:14 am    Post subject: MS3SPA on an O-200 Reply with quote
Hi Peter
I had to route my mixture for my O-200 from center firewall toward the passenger side C under the exhaust the then down to the back side of the Marvel carb.� I ended up making a bracket and bolting it to the bolts that support the oil sump(not the rings of nuts).� I used a "generic" throttle and mixture cable and then cut them to length very carefully as these cables can't be taken apart as the "locking" mechanism will come apart.� Bottom line is do not let the cable rub anywhere (I used lots of cable supports) and secure it near the carb so that it will no flex when pushed.
I have to say my plane was easy to buold until I got to the canopy (poor instruction) and firewall forward (no instruction) especially since I did not buy a firewall forward kit.
Hope this helps.
Glenn�
N676L��601XL Completed�
Chesapeake�
VA�
To: continental-list(at)matronics.com
Subject: MS3SPA on an O-200
Date: Mon C 29 Jun 2009 18:42:34 +1000
--> Continental-List message posted by: "Peter W Johnson" <vk3eka(at)bigpond.net.au>
Hi Guys C
Cheers
Peter
Wonthaggi Australia
Hotmail� has ever-growing storage! Don�t worry about storage limits. Check it out.
601XL N676L FLYING PHASE I
CHESAPEAKE VA
PostPosted: Mon Jun 29, 2009 4:38 pm    Post subject: MS3SPA on an O-200 Reply with quote
Glenn,
Thanks for the info. I still feel the lever is not the correct one for the O-200 (P/N 155-28 written on it, what’s yours?).
I managed to borrow one of Jon Crookes DVD’s for the canopy installation. It was much better than the manual.
The firewall forward kit from Zenith is the cowling and engine mount. The rest is up to you.
Peter
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of GLENN JOHNSON
Sent: Monday, 29 June 2009 9:10 PM
Subject: RE: Continental-List: MS3SPA on an O-200
[quote]Hi Peter
I had to route my mixture for my O-200 from center firewall toward the passenger side, under the exhaust the then down to the back side of the Marvel carb. I ended up making a bracket and bolting it to the bolts that support the oil sump(not the rings of nuts). I used a "generic" throttle and mixture cable and then cut them to length very carefully as these cables can't be taken apart as the "locking" mechanism will come apart. Bottom line is do not let the cable rub anywhere (I used lots of cable supports) and secure it near the carb so that it will no flex when pushed.
Hope this helps.
Glenn
[b]N676L 601XL Completed [/b]
Chesapeake
VA
GLJSOJ1
PostPosted: Tue Jun 30, 2009 2:53 am    Post subject: MS3SPA on an O-200 Reply with quote
Hi Peter
I bought my engine off Ebay out of a 150 and it was very complete.� Only thing I had to add was cooling baffles.� I'd check out the web sites for the carb and see what you can get from there or if you can get a rebuild / parts manual that would answer you question.� Hope that helps.
Glenn�
Chesapeake�
VA�
Subject: RE: MS3SPA on an O-200
Date: Tue C 30 Jun 2009 10:34:49 +1000
.ExternalClass .EC_shape {;} .ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.EC_EmailStyle21 {font-family:Arial;color:navy;} (at)page Section1 {size:595.3pt 841.9pt;} .ExternalClass div.EC_Section1 {page:Section1;}
Glenn C
Thanks for the info. I still feel the lever is not the correct one for the O-200 (P/N 155-28 written on it C what�s yours?).
I managed to borrow one of Jon Crookes DVD�s for the canopy installation. It was much better than the manual.
Peter
Sent: Monday C 29 June 2009 9:10 PM
Hi Peter
Hope this helps.
Glenn�
[b]N676L��601XL Completed�[/b]
Chesapeake�
VA�
List">http://www.matronics.com/Navigator?Continental-List
ronics.com
ww.matronics.com/contribution
Windows Live� SkyDrive�: Get 25 GB of free online storage. Get it on your BlackBerry or iPhone. [quote][b]
CHESAPEAKE VA
PostPosted: Tue Jun 30, 2009 3:21 am    Post subject: MS3SPA on an O-200 Reply with quote
Glenn,
Thanks, I have had a look around the ‘net but most info would come from a $70 parts manual.
I’ll see what else I can have a look at in my local airport.
Cheers
Peter
Sent: Tuesday, 30 June 2009 8:52 PM
Hi Peter
I bought my engine off Ebay out of a 150 and it was very complete. Only thing I had to add was cooling baffles. I'd check out the web sites for the carb and see what you can get from there or if you can get a rebuild / parts manual that would answer you question. Hope that helps.
Glenn
[b]N676L 601XL [/b][b]Completed [/b]
Chesapeake
VA
Date: Tue, 30 Jun 2009 10:34:49 +1000
Glenn,
Peter
Hi Peter
Hope this helps.
Glenn
Windows Live™ SkyDrive™: Get 25 GB of free online storage. Get it on your BlackBerry or iPhone.
5
6
7
8
9
ksheely(at)bellsouth.net
PostPosted: Tue Jun 30, 2009 4:01 am    Post subject: MS3SPA on an O-200 Reply with quote
Peter,
Mine comes in from the passenger side also. Check out this picture: http://3.bp.blogspot.com/_EJudOzvIdUA/Shs7qdwwf2I/AAAAAAAAAY0/g8-gPpQfdZI/s1600-h/Carb+Inlet+Elbow-15.jpg
Kevin
Sent: Monday, June 29, 2009 4:42:34 AM
--> Continental-List message posted by: "Peter W Johnson" <vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)>
Hi Guys,
Cheers
Peter
Wonthaggi ; &nbs=====================
PostPosted: Tue Jun 30, 2009 6:10 am    Post subject: MS3SPA on an O-200 Reply with quote
Kevin,
Thanks, looking at the picture I can see I have a different mixture lever. If I can find out what number I need I can order one.
Many thanks
Peter
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Kevin Sheely
Sent: Tuesday, 30 June 2009 9:58 PM
Subject: Re: Continental-List: MS3SPA on an O-200
Peter,
Kevin
[quote]From: Peter W Johnson <vk3eka(at)bigpond.net.au>
Hi Guys,
Cheers
Peter
Wonthaggi [b]
hdwysong
PostPosted: Wed Jul 01, 2009 9:40 am    Post subject: MS3SPA on an O-200 Reply with quote
My mixture lever P/N is a 155-409, Peter (MA-3SPA on a Cessna 150M w/ mixture control coming in from the starboard side much like Kevin's pic).�
HTH,
D
PostPosted: Wed Jul 01, 2009 8:34 pm    Post subject: MS3SPA on an O-200 Reply with quote
Hi Guys,
I managed to find the correct lever at my local aero engine builder. Straight swap for the one I had.
Cheers
Peter.
Hi Guys,
Cheers
Peter
Wonthaggi [b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Continental-List All times are GMT - 8 Hours
You cannot download files in this forum
