check lists, forced landings, and pilots
brian
PostPosted: Mon Jan 09, 2006 7:39 am    Post subject: check lists, forced landings, and pilots Reply with quote
I felt that my exchange with Roger was starting to get a bit acrimonious
so I quit without saying some of the things I wanted to say. (I guess I
must be getting old.) Pappy then popped up and made a number of my major
points for me. I am glad to see I am not thinking these things by myself.
I am not knocking emergency checklists. Heck, when everything is going
to hell in a hand basket and you are in real fear of dying, your brain
is not going to work too well. Having those emergency checklists burned
into your brain so you *do* something is a wonderful thing. Even if your
brain never comes back on-line there is a good chance that your
emergency check list will have accomplished something positive. It might
even save your life or save your airplane. This is A Very Good Thing.
But the checklist is no substitute for real thought as Pappy pointed
out. If you are thinking you probably have time to try a couple of
things that might not be in the checklist. This is especially true of
things like electrical and pneumatic problems in our airplanes. And it
is still true of a forced landing with a seized engine as you have to
select and evaluate a landing spot. It is amazing just how much time
only a little time is.
And any time you can make a decision ahead of time you are better off as
well. It takes time to make a decision and sometimes you do not have
that time. Engine failure in the pattern is a perfect example. If you
figure out from where in the pattern you can make it back to the runway
and then adhere to that decision you will be able to act more quickly in
the case where the fan stops turning. You can probably even figure out
where your emergency landing sites are going to be in the neighborhood
of your home field and then decide ahead of time whether each will be a
gear-up or gear-down site.
Roger, I apologize for apparently baiting you. I tend to do that,
especially when I perceive someone being dogmatic. For those of you who
have been around since the beginning, you remember how I used to bait
Mike McCoy. The reason I did it was because Mike was dogmatic and
inflexible. Everything was "by the book" with no apparent room for
thought and evaluation. Don't get me wrong; I thought Mike was a very
good pilot and instructor and his departure from the Yak/CJ community is
a loss to all of us. But he would get in these rigid though patterns
that would prevent him from even trying to analyze whether what he
"knew" was right. That was when I would "beat him up" on some topic to
try to get his attention and get him thinking about different
approaches. (<sigh> It didn't work and I get awshit points for not
figuring out a better way of dealing with him. Mea Culpa.)
My experience is such that, Any time someone says to you the words
"always" or "never" with regard to doing something in an airplane, they
are almost always wrong. There will always (ha, I just did it myself) be
an exception and only your brain will tell you when you need to exercise
that exception. Our brains have oversized frontal lobes for a reason.
Regardless of whether you think they are a gift of God or a lucky
survival trait, use them.
And please remember something else: we are all here because we love flying.
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
L39parts(at)hotmail.com
PostPosted: Mon Jan 09, 2006 10:52 am    Post subject: check lists, forced landings, and pilots Reply with quote
If there wasn't a need for thinking, there wouldn't be a need for a human at
the controls. You could just program a computer with the "always" and
"never" rules and send it off with a load of paying passengers. Look up the
casualty rates for drones if you can't visualize how well this would work on
your own.
viperdoc(at)mindspring.co
PostPosted: Mon Jan 09, 2006 11:36 am    Post subject: check lists, forced landings, and pilots Reply with quote
Ron,
That concept is closer than you think. It is said in my community that we are seeing the last manned fighters. This is the last generation of fighter pilots.
It is not very far off at all!
A chilling thought but true none the less.
By the way, the causalty rates for drones is less than that of the carbon units. Unless you are a raghead carrying a mortor tube though the date grove near Fallusia. Damned amazing what a Hell fire launched from a lurking predator will do to ruin an ambush! Not that I'm for taking the human out of the cockpit. I'm not! But it will soon be a fact of life as we know it.
Sad but true, the carbon units will be coming out of the cockpits to be replaced by silicon waffers.
I can see the swagger at the causual bar on Friday night.. "Hi, I'm R2D2 cuttie... does your silicon go all the way to your really nice waffers? ...wanta play with my pigtail and jiggle my antennae?"
Dogmatic Viperdoc
PostPosted: Tue Jan 10, 2006 6:44 am    Post subject: check lists, forced landings, and pilots Reply with quote
Roger,
I don't doubt what you say, but in fighters it doesn't matter much what the
crash rate is. When they fall out of the sky, they tend to fall on people
we want to kill anyway in places where we won't be sued for damages. How do
you feel about the prospects for pilot-less airliners? Are you looking
forward to riding in them?
I don't have the statistics, so I'll quote someone who has a lot of data and
knows far more about it than I do: Burt Rutan. He said that if the U-2 had
the casualty rate of the Global Hawk drone, the Air Force/CIA would have
used them all up, had to rebuild the factory and make a second production
equal to the first, and they would all be used up by now. He made this
comment at Oskosh a few years ago.
86 U-2s were built and 35 of the 50s/60s production are still in service,
largely because each has pilot that really wants go be at home when the
mission is over. I've never come across a silicon-base unit that cared one
way or the other.
When did the US replace this obsolete old fashion pilot-operated aircraft
that first flew in 1955? It's only an estimate, but currently it's slated
to be completely replaced by Global Hawk in 2011... if they can get the
production rate to exceed the crash rate.
Where would be now without slicone-based high speed digital computers? A
better question might be where would be if we had a couple of Kelly
Johnson's at work in a couple of Skunk Works.
PostPosted: Tue Jan 10, 2006 12:08 pm    Post subject: check lists, forced landings, and pilots Reply with quote
Ron,
I'm with you on taking the human out of the cockpit. I suspect we will learn the same lesson we learned with the gun. On the otherhand, I have seen the future...and it is closer than we give credit. The issues that Burt Rutan spoke of are past in many ways.
No, I personally do not want to fly a pilot-less airliner.
The day is coming... we already have commuter train lines and airport shuttles that are remotely controlled.
Doc
PostPosted: Tue Jan 10, 2006 7:54 pm    Post subject: check lists, forced landings, and pilots Reply with quote
