Electric dependent Engine - Pucker Factor?
PostPosted: Mon Jun 29, 2009 7:30 am    Post subject: Electric dependent Engine - Pucker Factor? Reply with quote
At 04:55 AM 6/29/2009, you wrote:
I have been following the posts on this list for a year or so and �Lectric Bob�s writings for maybe 10 years. This has led to my understanding of failure tolerant design, so that if any part fails (as any part can and will) you go to plan�B� with out needing to raise a sweat. Not considered as possible failures in this case are such things as prop bolts, wing struts, connecting rods and the like.
I am considering the use of an Eggenfellner E6.0 Subaru Auto conversion. The electrical system architecture will basically be Z-19.
There are electrical system designs that are very failure tolerant even for electrically dependent engines. And there are more and more of these electrically dependent engines being used all the time. But usually you have 2 fuel pumps, 2 electrical paths to the fuel injection/electronic ignition, etc.
The Egg has 1 ECU (Engine Control Unit) computer. Without it functioning the fan out front does not rotate. It is a computer whose heart is a microprocessor.
Is a microprocessor in the same league as a prop bolt for reliability?
Probably not . . . but they CAN be pretty good.
How's that for a non-quantified answer? Reliability
is an oft discussed topic here on the List. When
we speak of reliability in the military or TC
aircraft world, the discussion necessarily includes
a study of failure rates for individual components
(taken from a handbook written by folks who
purport to know such things). The last reliability
study I witnessed in my career involved the mathematical
analysis of all the pieces and parts that went
into the fabrication of a super-sonic target
we were building for the Navy . . .
http://www.ordnance.org/aqm37c.htm
We expended perhaps 1000 man-hours compiling
the data and publishing a report. I don't recall
now what the numbers were. I don't put much
credence in such activities. They are
exercises in bureaucratic process that make
bureaucrats happy . . .. and they paid us
for it!
Bottom line is that most such systems, if they
are crafted with legacy products by skilled
workers and screened for defects at time
of manufacture will perform as advertised
with low risk of failure. There's that
non-quantified "low" thing again.
But suppose Eggenfellner spent $100,000 and
produced a detailed reliability study of the
system as installed per his instructions
posted at:
http://www.eggenfellneraircraft.com/electrical.htm
Suppose further that he offered a number
of 1.6 failures per million flight hours.
How would you use that number? If you have
competing suppliers and the other guy says
his gizmo has only 0.8 failures per million
flight hours, would you pay double the cost
to get double the "reliability"?
Further, the past week's discussion on a
Subaru powered RV-10 crash vividly illustrates
that a system with 1 failure per trillion
flight hours isn't worth beans if you don't
craft power sources with similarly impressive
numbers.
What is the answer for this? Simply accept it and increase the pucker factor?
Being a diligent observer of demonstrated service
history is a good place to start. I've been
chastised soundly on this List for suggesting
that my observations of B&C's return products
was not a proper expression of "reliability".
I was able to offer from first hand experience
that with thousands of devices in service, his
return rates were on the order of 1-2 units
per month for repair of user induced damage.
I observed no returns for failure of the
product.
Not being inclined to spend $100,000 on a formal
reliability study, I suggested that those
observations were encouraging . . . especially
since we knew how to produce failure tolerant
systems that did not depend on a functioning
alternator for comfortable termination
of flight.
Also, I think that I have seen Bob mention that he might be publishing a Z-19 modification, specific to the Egg requirements and also some potential pre-flight checklist recommendations for Z-19 and perhaps other designs, Has this been done and I have missed it?
Some years ago I had some discussion with
Eggenfellner about a product-specific Z-figure.
I don't remember details of the conversation
now except that the idea was not received with
enough enthusiasm for the project to move
forward.
The Eggenfellner website gives us lip-service
for a resource on technique but includes a
statement, "Avoid being lured into thinking that
you can create your own alternative to the EXPBUS
and save time and money."
I've studied the EXPBUS (and similar products)
and written about them extensively. It's easy
to demonstrate that they DO NOT save money.
You can search aeroelectric.com for those
discussions.
At the same time, Eggenfellner's instructions are
painstakingly crafted and well illustrated. I have no
first hand knowledge as to how many of these
systems are flying nor do I know the history
of field service problems. Queries to the various
Lists have to be your most useful places to
put a dipstick into tribal knowledge. But
be aware that while dark-n-stormy night stories
abound in aviation, few tellers of such stories
understand the simple ideas nor do they always
have access to the facts of reported failures.
While there are things in the Eggenfellner
design I would not embrace, it's his kitchen,
his recipe for success, and his reputation
on the line. If you want to go the Z-19 route,
then let's talk about it here on the list
and tap the grey matter and experience of the
membership.
So what ever stories you uncover, bring them
to the AeroElectric List for the assistance
of many minds who are skilled at sifting
significance out of the noise.
Given the demonstrated service history of
automotive engine controllers (in environments
much more stressful than under your cowl)
I'll suggest that concerns for the hardware
are probably not well founded. These pieces
of hardware perform long and hard for
thousands of hours over the lifetime of
the vehicle. It is more likely that your
unhappy day in the cockpit will arise from
failure to exercise due diligence in the
crafting or maintaining your electrical system . . .
or still more likely from venturing into
a flight situation beyond the abilities
of you or your airplane.
There are plenty of nice ol' Lycomings out
there with a huge history of demonstrated
performance that doesn't seem to discourage
many of our ranks from launching into the blue
behind them.
Bottom line is that the risks are never
zero. We can only do our best to mitigate
those risks to acceptable levels. If you're
really worried about it . . . then don't do it.
A worried pilot with a good system is probably
at greater risk than a skilled and thoughtful
pilot with a mediocre system. Your likelihood
of walking away from an unplanned arrival
with the earth has little to do with reliability
numbers and a lot to do with how you approach
duties as pilot, designer and maintainer of
the airplane. This fact has been demonstrated
countless times throughout the history of aviation.
This is why accident rates for OBAM aircraft
are pretty much in step with accident rates in
TC aircraft. Both sets of pilots run off the same
runways, fly into the same mountains, run the
same batteries to destruction . . . or fail to
tighten the same oil drain plug.
Bob . . . [quote][b]
deej(at)deej.net
PostPosted: Mon Jun 29, 2009 7:52 am    Post subject: Electric dependent Engine - Pucker Factor? Reply with quote
posted at:
Just fyi, those are an older set of wiring instructions for the
Eggenfellner package. The latest instructions can be found at
<http://www.eggenfellneraircraft.com/ESeriesInstallationGuide.pdf>
starting on page 45 with other references for the package at
<http://www.eggenfellneraircraft.com/iindex.htm>
Please note that the current wiring instructions are quite different
from the old, and do not include the EXPBUS. Refer to page 51 for a
schematic.
fyi
-Dj
Dj Merrill - N1JOV
Sportsman 2+2 Builder #7118 N421DJ
http://deej.net/sportsman/
"Many things that are unexplainable happen during the construction of an
airplane." --Dave Prizio, 30 Aug 2005
