Ground planes again
John Herminghaus
PostPosted: Mon Jul 06, 2009 10:36 am    Post subject: Ground planes again Reply with quote
Bob,
One last question. With a carbon fiber can the ground plane be on the
inside or should be on the outside.
John Herminghaus
John Herminghaus
Lancair IV-P
I-VVVV
Bruce(at)glasair.org
PostPosted: Mon Jul 06, 2009 11:19 am    Post subject: Ground planes again Reply with quote
I don't think it matters.
Bruce
www.Glasair.org
mprather(at)spro.net
PostPosted: Mon Jul 06, 2009 12:10 pm    Post subject: Ground planes again Reply with quote
I agree..
However, since the carbon fiber is somewhat conductive and therefore
shielding in nature, I might be concerned if the thickness of the surface
(including any foam/honeycomb core material) were significant.
Significant depends on what frequency the antenna operates at. The higher
the frequency, the more critical. If it's vhf it probably won't have any
major tuning effect. If transponder, I suspect a noticeably de-tuning
effect might be noticed. I would also guess that any de-tuning can be
addressed with a slightly longer radiator. You would need proper
equipment to check that out.
Matt-
Bruce
www.Glasair.org
