h20maule(at)hotmail.com Guest
Posted: Thu Jul 09, 2009 3:38 pm Post subject: Firestar Weight and Balance |
Anyone know the formula? I've never created one from scratch..
Quote: | Subject: Re: New Videos
Date: Thu C 9 Jul 2009 16:25:30 -0700
--> Kolb-List message posted by: "ces308" <ces308(at)ldaco.com>
zeprep251(at)AOL.COM wrote:
> Chris C That has a familiar sound track!
> G Aman
Yeah.....Ain't she sweet !.....lol
chris ambrose
http://forums.matronics.com/viewtopic.php?p=252383#252383
&g============
Hotmail® has ever-growing storage! Don’t worry about storage limits. Check it out. |
aslsa.rng(at)gmail.com Guest
Posted: Thu Jul 09, 2009 6:34 pm Post subject: Firestar Weight and Balance |
Daniel, I've had to do this on my Firestar and a few other aircraft so if you want a quick primer, I'll give it a shot. It helps to have a helper to record values and read the tape when you set the pilot's position. One assumption here is that your Firestar has a 2 stroke engine so there is no oil weight variable. - Get the aircraft in position. For a Kolb, prop up the tail wheel until the bottom of the wing is at 9 degrees.
- I don't like to work with negative numbers so I set zero datum by dropping a plumb line from the front of the nose cone.
- Run a tape measure from the zero datum to at least the contact point of the tail wheel
- Now start dropping plumb lines. You need the pilot station (your navel when seated in the aircraft as you would be while flying, the contact point of the main gear, the leading and trailing edge of the wing, the center of the fuel tank and the contact point of the tailwheel.
- Weigh the aircraft in position.
- Calculate the datum for the 18, 25 and 35% chord position.
- Use heaviest pilot wt. say 270 lb, and 1/2 gallon of fuel as the most fwd cg condition. it should come out at or aft of the 18% point.
- Use lightest pilot wt. say 150 lb. and full fuel as the most aft cg condition. It should fall at or fwd of the 35% point.
Well that's how I did it and the FAA rep or the DAR never questioned my data.
Rick
On Thu, Jul 9, 2009 at 6:30 PM, daniel myers <h20maule(at)hotmail.com (h20maule(at)hotmail.com)> wrote:
[quote] Anyone know the formula? I've never created one from scratch...
> Chris, That has a familiar sound track!
> G Aman
Quote: |
| [b]
Posted: Thu Jul 09, 2009 6:42 pm Post subject: Firestar Weight and Balance |
Thanks! this should help...i appreciate it
Daniel
Date: Thu C 9 Jul 2009 21:31:54 -0500
Subject: Re: Firestar Weight and Balance
Daniel C I've had to do this on my Firestar and a few other aircraft so if you want a quick primer C I'll give it a shot. It helps to have a helper to record values and read the tape when you set the pilot's position. One assumption here is that your Firestar has a 2 stroke engine so there is no oil weight variable. - Get the aircraft in position. For a Kolb C prop up the tail wheel until the bottom of the wing is at 9 degrees.
- Now start dropping plumb lines. You need the pilot station (your navel when seated in the aircraft as you would be while flying C the contact point of the main gear C the leading and trailing edge of the wing C the center of the fuel tank and the contact point of the tailwheel.
- Calculate the datum for the 18 C 25 and 35% chord position.
- Use heaviest pilot wt. say 270 lb C and 1/2 gallon of fuel as the most fwd cg condition. it should come out at or aft of the 18% point.
Rick
On Thu C Jul 9 C 2009 at 6:30 PM C daniel myers <h20maule(at)hotmail.com (h20maule(at)hotmail.com)> wrote:
Hotmail® has ever-growing storage! Don’t worry about storage limits. Check it out. [quote][b]
by0ung(at)brigham.net Guest
Posted: Fri Jul 10, 2009 11:43 am Post subject: Firestar Weight and Balance |
Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>.
If anyone is interested I built a spread sheet for W&B reply direct and I will forward the attachment. by0ung(at)brigham.net (by0ung(at)brigham.net)
Boyd Young
MkIII C
Do not archive.
