Switch wiring conundrum
mark.supinski(at)gmail.co
PostPosted: Fri Jul 03, 2009 7:58 pm    Post subject: Switch wiring conundrum Reply with quote
Hello everyone-
I've been wracking my brain trying to figure out a way to control my EFI injectors using a single 2-XX switch.� I can't find a way to do what I want to do (perhaps there is no way).
Here's what I'm trying to accomplish:
I have 2 banks of injectors.� I need to be able to wire them such that I have a single 3 position switch (Primary - Both - Secondary).� That part is easy enough using a 2-10.� Here's the added trick:� whenever Both is not selected, I need to tie a certain line on the EFI to ground.� (This lets the EFI know one bank is offline & it automatically doubles the fuel flow through the remaining bank.)
The suggested implementation from the EFI manufacturer is to wire each bank to a 2-3.� One side of 2-3 control whether the bank gets power, the other side controls whether the EFI line ties to ground.� When an injector bank has failed, the pilot is "guessing" which bank to take offline.� If he guesses right, the engine smooths out & all is well for a no-sweat landing.� If he guesses wrong, the engine runs off & he must quickly restore power to the bank he just turned off & remove power from the "other" bank.� Using two separate switches for this�seems like a recipe for frantically flipping switches to try to get the engine back on if the pilot guesses wrong.� My idea is that if it is a single pri-both-sec switch, it is much easier to simply reverse the position of the single switch you already have a hold of should the guess be wrong.
Hopefully someone is cleverer than I am and can figure out how to do this without�requiring 2 switches!� Or, at least I can find out it is impossible & I can resign myself to having two switches.
Mark
bob(at)bob-white.com
PostPosted: Fri Jul 03, 2009 8:52 pm    Post subject: Switch wiring conundrum Reply with quote
Hi Mark,
There isn't as much of a problem with the two switch solution as you
are imagining. When you turn off one bank and the engine doesn't run
better, you already have your hand on that switch and can immediately
turn it back on. Then just turn off the second switch (which is
probably, or should be, right next to it).
Bob W.
On Fri, 3 Jul 2009 21:55:14 -0600
"Mark R. Supinski" <mark.supinski(at)gmail.com> wrote:
Hello everyone-
injectors using a single 2-XX switch. I can't find a way to do what I want
I have 2 banks of injectors. I need to be able to wire them such that I
have a single 3 position switch (Primary - Both - Secondary). That part is
easy enough using a 2-10. Here's the added trick: whenever Both is not
selected, I need to tie a certain line on the EFI to ground. (This lets the
to a 2-3. One side of 2-3 control whether the bank gets power, the other
side controls whether the EFI line ties to ground. When an injector bank
has failed, the pilot is "guessing" which bank to take offline. If he
the bank he just turned off & remove power from the "other" bank. Using two
separate switches for this seems like a recipe for frantically flipping
switches to try to get the engine back on if the pilot guesses wrong. My
without requiring 2 switches! Or, at least I can find out it is impossible
Mark
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
3.8 Hours Total Time and holding
Cables for your rotary installation - http://roblinstores.com/
mrspudandcompany(at)veriz
PostPosted: Sat Jul 04, 2009 4:45 am    Post subject: Switch wiring conundrum Reply with quote
Hello everyone-
I've been wracking my brain trying to figure out a way to control my EFI injectors using a single 2-XX switch. I can't find a way to do what I want to do (perhaps there is no way).
I have 2 banks of injectors. I need to be able to wire them such that I have a single 3 position switch (Primary - Both - Secondary). That part is easy enough using a 2-10. Here's the added trick: whenever Both is not selected, I need to tie a certain line on the EFI to ground. (This lets the EFI know one bank is offline & it automatically doubles the fuel flow through the remaining bank.)
The suggested implementation from the EFI manufacturer is to wire each bank to a 2-3. One side of 2-3 control whether the bank gets power, the other side controls whether the EFI line ties to ground. When an injector bank has failed, the pilot is "guessing" which bank to take offline. If he guesses right, the engine smooths out & all is well for a no-sweat landing. If he guesses wrong, the engine runs off & he must quickly restore power to the bank he just turned off & remove power from the "other" bank. Using two separate switches for this seems like a recipe for frantically flipping switches to try to get the engine back on if the pilot guesses wrong. My idea is that if it is a single pri-both-sec switch, it is much easier to simply reverse the position of the single switch you already have a hold of should the guess be wrong.
Hopefully someone is cleverer than I am and can figure out how to do this without requiring 2 switches! Or, at least I can find out it is impossible & I can resign myself to having two switches.
Mark
I think you are overlooking an important point. With one switch you have a "single point of failure", which cauld kill both EFI's simultaneously. My preference/recommendation is TWO switches.
Roger
klehman(at)albedo.net
My first thought would be to use a transistor or NAND gate chip to
reverse the logic of the on signal.
Second thought is that you may not want to flick switches in a hurry. I
run independent systems and it does take a second to fill the second
fuel rail if I don't prime it first. By that I mean the second fuel rail
seems to get the fuel very slowly sucked out of it during cruise.
Third thought is that I would not use a single switch point of failure
for both injectors anyway. Note that it is no big deal if the engine
gets double the required fuel for a short period. It will still run and
make power during that time. Another option is to use a mechanical bar
arranged to mechanically operate two or more switches simultaneously.
Ken
Mark R. Supinski wrote:
Hello everyone-
Mark
PostPosted: Sat Jul 04, 2009 7:54 am    Post subject: Switch wiring conundrum Reply with quote
Well, that's certainly something to stew on.�
I wish I had better information on what the failure modes for these injectors really were.� For instance -- do injectors fail open or fail closed? Wiring in the switching is optional in the manual - implying I could happily go flying with no ability to disable injector banks in flight.� I truly do not have room for two switches without making radical changes.� I think I have to go stare at the drawings and the physical panel some more & either come to terms with no switches or two switches...
Thanks all-
Mark
On Sat, Jul 4, 2009 at 6:43 AM, Roger <mrspudandcompany(at)verizon.net (mrspudandcompany(at)verizon.net)> wrote:
[quote] �
Hello everyone-
Mark
I think you are overlooking an important point.� With one switch you have a "single point of failure", which cauld kill both EFI's simultaneously.� My preference/recommendation is TWO switches.
Roger
tp://forums.matronics.com
Sam
PostPosted: Sat Jul 04, 2009 12:06 pm    Post subject: Switch wiring conundrum Reply with quote
Mark - FWIW, I went through this same conundrum earlier this year.� I finally grasped the fact that two switches would be the most reliable.�
Sam
www.samhoskins.blogspot.com
On Sat, Jul 4, 2009 at 10:52 AM, Mark R. Supinski <mark.supinski(at)gmail.com (mark.supinski(at)gmail.com)> wrote:
[quote] Well, that's certainly something to stew on.�
Thanks all-
Mark
Hello everyone-
Mark
Roger
a>http://forums.matronics.com
Sam Hoskins
PostPosted: Sat Jul 04, 2009 6:09 pm    Post subject: Switch wiring conundrum Reply with quote
FWIW here is my opinion on electronic injectors:
The most likely failure mode is low flow due clogging or zero flow due
to a wiring fault. Clogging/leaking risk is likely raised on some
aircraft due to using filters that are not as fine as in automobiles.
Coil failure resulting in no flow or continuous (stuck on) flow is rare
but both have been known to occur I'm told. I consider a stuck on
injector or a leaking injector to have no serious consequence for
aviation other than a rough idle after landing. And of coarse some fire
risk when on the ground or at idle.
ie. the major risk is a wiring problem or blown fuse/relay caused by a
wiring problem.
Ken
injectors really were. For instance -- do injectors fail open or fail
closed?
PostPosted: Sat Jul 04, 2009 8:27 pm    Post subject: Switch wiring conundrum Reply with quote
Thanks to everyone for their thoughts.
I "bit the bullet" and celebrated the 4th of July by spending a delightful 5 hours under my instrument panel moving components / rewiring / etc to shoe-horn in room for another switch -- which got in there with 0.05" to spare.� God then smiled on me & miraculously there were even two new 2-3 switches squirreled away in the back of the tool chest to allow me to directly replace the old 2-10.
Mark
On Sat, Jul 4, 2009 at 8:05 PM, Ken <klehman(at)albedo.net (klehman(at)albedo.net)> wrote:
[quote] --> AeroElectric-List message posted by: Ken <klehman(at)albedo.net (klehman(at)albedo.net)>
The most likely failure mode is low flow due clogging or zero flow due to a wiring fault. Clogging/leaking risk is likely raised on some aircraft due to using filters that are not as fine as in automobiles.
Coil failure resulting in no flow or continuous (stuck on) flow is rare but both have been known to occur I'm told. I consider a stuck on injector or a leaking injector to have no serious consequence for aviation other than a rough idle after landing. And of coarse some fire risk when on the ground or at idle.
ie. �the major risk is a wiring problem or blown fuse/relay caused by a wiring problem.
Ken
I wish I had better information on what the failure modes for these injectors really were. �For instance -- do injectors fail open or fail closed?
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
PostPosted: Thu Jul 09, 2009 6:20 am    Post subject: Switch wiring conundrum Reply with quote
in there with 0.05" to spare. God then smiled on me & miraculously
I think this is a good move my friend. In about a year,
I'll be able to share the unfortunate details on an electrical
system wherein the system designer took ingredients for
biscuits, bread, hot cereal, and dumplings and
stirred them into a new product that turned out to
be less than palatable . . . and was in fact
hazardous to health.
It's in our best interests to first consider the
manufacturer's instructions for integrating any critical
components into an airplane. But it does not automatically
follow that the manufacturer of a product is well versed
in the art of failure mode effects analysis and design
for failure tolerance. We should strive for the lightest,
least expensive and least numbers of parts that minimize
the need for pilot attention and intervention. I.e. the
elegant solution. EVERY design is fair game for critical
review.
There's no such thing as a SAFE airplane, automobile,
handgun or skateboard. There are considerations of design,
installation, operation and environment that always yield
to logical incorporation of simple-ideas into minimum risk
recipes for success.
( -Thomas Paine 1776- )
