		wingnut
				 Posted: Sun Jul 05, 2009 10:37 am    Post subject: Unmounting engine |
				I'd like to address a persistent oil leak in a rear accessory case of my 912UL. It's a slow drip that I could live with if it weren't that it drips on the lower motor mounts. The oil and the heat conspire to ruin the mounts. Only problem is that I have to unmount the engine to get to the problem area. I didn't build this airplane and I've never done any work this involved. Any advice on this? Anything in particular I should look out for?
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
		johnciolino(at)comcast.ne Guest
				 Posted: Mon Jul 06, 2009 3:08 am    Post subject: Unmounting engine |
				Luis,
 If you can assess what you need to with the motor mount in place I would
 sugggest leaving the motor mount on the engine and removing the engine/mount
 from the firewall. It's been a while, but I remember that getting the mount
 on the engine was a bit tricky.
 When I took my engine off to make the repair to the stator, I bolted a 2'
 x2' piece of 3/4" plywood to the propeller hub, used an engine hoist to
 removed the engine, then tipped the nose down and lowered the plywood onto a
 knee high stand I made from 2x4s and clamped the plywood in place. This made
 an excellent engine stand and was very stable.
 To re-mount the engine, just reverse the process. I did it by myself and did
 not feel uncomfortableat any point.
 Good luck
 John Ciolino
 Model IV-1200
 N9294Y
		wingnut
				 Posted: Mon Jul 06, 2009 7:36 pm    Post subject: Re: Unmounting engine |
				So I gather you removed the propeller? I was wondering if that would be necessary. I have access to an engine hoist. I'm hoping that will be enough.
 Thanks for the tip in the engine mount. I'll give that a shot.
  	  | Quote: | 	 		  When I took my engine off to make the repair to the stator, I bolted a 2' x2' piece of 3/4" plywood to the propeller hub, used an engine hoist to
 removed the engine, then tipped the nose down and lowered the plywood onto a knee high stand I made from 2x4s and clamped the plywood in place |
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
