Posted: Sun May 10, 2009 11:32 am Post subject: 701 fuel system design |
I've seen a number of different fuel system designs on 701s. My big worries
are the placement of the fuel valve(s) and the gascolator. I want the
capability to select left, right or both to be able to control uneven flow.
Normally I would fly with "both" but switch to left or right if one tank was
draining faster. I'd also prefer the gascolator(s) to be where the Zenith
plans call for them (behind seats) as I'd like a gascolator to be at the
actual low point in the system. I know that some builders place their
gascolators on the firewall as a localized low point. But with the
gascolator forward I just don't see how you will ever get water or junk out
of the other low points in the system.
I'd like a "real" gascolator but placed where the plans call for the Zenith
"box". But it is tricky to mount a conventional gascolator there such that
you can drain it and open it for cleaning,
Places I have seen valves with pros and cons:
- Zenith design with off/on valve on floor by flap handle. Pros: single
gascolator behind seats, don't need access to valve during flight. Cons: no
"both" position.
- behind copilot's head towards the top off the outside wall. Pros: short
runs on lines from individual tanks, single "down" line to a single
gascolator. Cons: awkward to reach.
- centered on crossbar behind and above pilot and copilot just below roof.
Pros and cons are like above.
- on floor near flap handle. Pros better (but not great) access. I've got
chunky thighs and reaching (let alone seeing) the valve is hard. Not an
issue with an off/on valve but more important with a left-both-right valve.
Cons: two gascolators behind seats.
- on panel. Pros: good access to, and visibility of valve handle. Cons:
probably need actual valve on firewall with extension to panel.
One interesting idea I saw (N701RR?) is to not run the line(s) down, behind
the seats and then forward. Instead run them forward from the wing roots and
then down the diagonal steel tubes to the glare shield and firewall.
How have others thought this through?
-- Craig
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
lgold(at)quantum-associat Guest
Posted: Sun May 10, 2009 3:51 pm Post subject: 701 fuel system design |
Craig,
My kit came with 4 tanks (40 Gal) and I did not like the idea of routing the
fuel lines and gascolator behind the seat where I would not be able to
detect leaks.
I am pleased with my installation. I ran the lines from the tanks to the
forward wing root on each side where I put selector valve with inside tank,
outside tank, and off positions. From their I ran the stainless mesh covered
fuel lines down and forward to the fire wall along the steel frame at the
sides of the windshield. I placed the gascolator forward of the firewall on
the bottom-most part of the firewall away from the exhaust system. I was
concerned about potential vapor lock, but a week of flying in 100+ degree
weather in Death Valley and Nevada & Arizona high desert dispelled this
concern.
If I has only a single tank in each wing I would use the same setup with an
on-off selector switch on each wing root. Simple and safe.
Les
Posted: Mon May 11, 2009 10:56 am Post subject: 701 fuel system design |
Thanks Les,
Running the lines forward looks appealing. Do you have any pictures? How do
you protect the lines where they pass through the glare shield - just the SS
braid?
BTW: if you ever come out to fly the canyons in southern Utah feel free to
drop by and visit me in Northern Utah at 36U in Heber, UT.
-- Craig
lrm(at)skyhawg.com Guest
Posted: Mon May 11, 2009 6:20 pm Post subject: 701 fuel system design |
Check out my page on fuelsystem, you might find it interesting.
www.skyhawg.com/fuelsystem.html. Take care, Larry, N1345L
Craig Payne wrote:
Thanks Les,
braid?
-- Craig
Posted: Mon May 11, 2009 8:40 pm Post subject: 701 fuel system design |
Thanks, food for thought.
-- Craig
jetboy
Posted: Tue May 12, 2009 12:16 am Post subject: Re: 701 fuel system design |
There are a few guidelines I was told by an experimental builder, that all fuel lines should run downhill to the lowest point, of a drainable location, thence travel uphill to the carb inlet.
With the CZAW layout supplied, most of this was not possible due to the location of the andair fuel selector on one side of the rear cabin meaning the fuel line from the other side had to travel up and over to the valve.
I scrapped that layout, instead running the fuel lines down from the cabin wing roots, behind the pillars, across the rear of the seat back, into the fuel selector which is located just above the control tunnel mounted on the seat back panel. There is an area there, inside the working arc of the control system, that clears everything. The single fuel line exits the valve, runs down and across to an ACS gascolator on the right side panel just aft of the main gear mountings. Drain valve hangs through a hole there. mounting was easy with a P clamp around each line connection. The otlet line runs along the floor on the right side, thru the firewall and up to the carb. As I have a Jabiru, with a low carb position and gravity feed I have not required any fuel pumps.
I found the location of the fuel selector, forward facing and between the seats, easy to reach and operate - perhaps harder to see but easy to feel the correct position, and I orientated it so the pointer is towards the tank selected (had to re-label the faceplate)
Hope this explanation helps the planes too far away for a photo right now.
Ralph
_________________ Ralph - CH701 / 2200a |
Posted: Fri May 15, 2009 2:46 pm Post subject: 701 fuel system design |
Craig,
I'll take some pictures this weekend and send them out. I'm not certain what
a glare shield is, but each time I went through anything with the SS fuel
lines I used a rubber grommet.
FYI, I flew my 701 from San Francisco to S. Utah and Arizona last summer.
This summer I fly to Oshkosh, but would like to fly to N. Utah one of these
days...
Les
Posted: Fri May 15, 2009 3:04 pm Post subject: 701 fuel system design |
Thanks. The glare shield is the curved sheet on top and between the firewall
and instrument panel, aka top front skin. 7F14-4
If you pass through northern Utah on your way to or from Oshkosh and want to
stop at 36U let me know.
-- Craig
d.shrader
Posted: Tue Jun 30, 2009 8:51 pm Post subject: Re: 701 fuel system design |
Les
I am installing Aux. tanks also and that is my idea also "selectors at wing root Main/Aux/off" then to the normal gascolator and to a firewall shutoff. My question for you is what selectors did u use and can u share pics of your instlation?
Also is there any problem with the selectors at the wing root and removing the wing?
Thanks Dave
Curt.Thompson(at)verizon. Guest
Posted: Tue Jun 30, 2009 9:08 pm Post subject: 701 fuel system design |
There is one CH701 incident in the NTSB database where the pilot forgot to
turn the valve off on one of the lines when he landed. He normally did
that. When he got in next time, he turned the valve off instead of on.
Engine ran out of fuel shortly after takeoff.
BTW, I found a dozen or so incident reports in the database. Only one
fatal. Most were engine/fuel related.
Curt
xl(at)prosody.org Guest
Posted: Tue Jun 30, 2009 9:53 pm Post subject: 701 fuel system design |
I have a program that goes through the NTSB database daily looking
for Zenith incidents. Last count, 25 701, 6 801, and a few other 701s
under the Zenair model. The report is at:
NTSB Accident Data for Zenith, Zodiac, Zenair, 801, 701, 601, amd,
czech as of 06/30/2009 04:04 GMT-07:00
http://www.cleanh2o.com/633z/ntsb/
Joe E (at) BFI
N633Z, 585 hours + climbing
CH601XL
p.s. I'll be working the ramp at the AWO flyin next week,
when I can fly in from BFI. My plane will be there if I am.
On Tue, 30 Jun 2009, Curt Thompson wrote:
Quote: |
.......snip
d.shrader
Posted: Tue Jun 30, 2009 11:56 pm Post subject: Re: 701 fuel system design |
Curt.Thompson(at)verizon. wrote: | There is one CH701 incident in the NTSB database where the pilot forgot to
Curt
Too true Curt but that is the only way to control your fuel and proper fuel managment is part of flying. General aviation is full of fuel related incidents as well as commerical aviation. I'm trying to reduce other fuel related problems excessive fuel imbalance can be just as dangerious as fuel starvation. My thinking on the two fuel selectors at the wing roots is it's very visable (I.E.unlike John Denver's) and easy to get at.
Reguards. Dave
dwilde(at)clearwire.net Guest
Posted: Wed Jul 01, 2009 7:11 am Post subject: 701 fuel system design |
I just installed valves at each wing root inside the cockpit. I can
easily reach each valve and use it to balance fuel use between tanks. I
added a note in my preflight checklist to make sure all fuel valves are
on for takeoff.
Dan Wilde
Reguards. Dave
ggower_99(at)yahoo.com Guest
Posted: Wed Jul 01, 2009 9:23 am Post subject: 701 fuel system design |
Hello Dan,
I installed the same (one valve in each side of the cabin). My 701 with only the main valve (floor valve), will always use first the gasoline from the right wing. No problem in short flights (less than an hour), when the plane is parked both tanks will even in a few minutes.
In long XCountry flights (more than 2.5 hrs a leg) this has worked for me:
Take off with both side valves open, for security, at cruise altitude I close the right tank for one hour (in use the left tank), at one hour, I open the right valve (keep both valves opened for the rest of the flight) and when landing I always land with both tanks (almost) even.
For "Simplicity and lightness" I should only add the right wing valve, left one never closed for balance fuel.
I always plan my flights for less than 3 hrs a leg... I get a little nervous when the "trusty" electric needles get close to 1/4...
Here there are only a few landing strips, less with gasoline available.
Saludos
Gary Gower
Flying from Chapala, Mexico
Coordenadas Google Earth.
20°18'33.86"N 103° 9'36.99"W
701 912S 251 hrs of fun
Building a 601 XL Jab 3300.
--- On Wed, 7/1/09, Dan Wilde <dwilde(at)clearwire.net> wrote:
Quote: |
Subject: Re: Re: 701 fuel system design
To: zenith701801-list(at)matronics.com
Date: Wednesday, July 1, 2009, 11:10 AM
--> Zenith701801-List message posted by: Dan Wilde <dwilde(at)clearwire.net (dwilde(at)clearwire.net)>
on for takeoff.
Dan Wilde
Reguards. Dave
&nNavigator?Zenith701801-List" target=_blank>http://www.matronics.com/Navig========================
NYTerminat(at)aol.com Guest
Posted: Sun Jul 05, 2009 11:01 am Post subject: 701 fuel system design |
Dave,
Answering your questions:
I don't think there are problems removing the wings with selectors inside
the cockpit at the wing root. Just disconnect the lines to the wings at that
point. Having said this I need to add that I have never disconnected them
and would not recommend this if you plan to remove the wings a lot unless
you put some type of quick disconnect as opposed to just pushing the lines
onto a nipple.
It would be difficult sending pics of my installation. I ran the lines
inside the cockpit from the two selectors down along the steel cage on
either side of the windshield, through the firewall and to a single
gascolator at the lowest point on the firewall. This is the lowest point in
the fuel system and the lines run downhill from the tanks so that water
could not collect anywhere else than the gascolator. From there I ran the
fuel lines up through a fuel flow meter and an aux electric pump (which I
have never had to use) to the engine. I was concerned that putting the
gascolator forward of the firewall could lead to vapor locks.. Not so; I
have 250 flight hours, some of it in 105+ air temps without any problems.
Les
Posted: Sun Jul 05, 2009 6:10 pm Post subject: 701 fuel system design |
Gary,
If you don’t want to get nervous about your “trusty” electric needles to determine fuel availability, consider a fuel flow measuring system. The fuel flow sensor added about $100 to the cost of my Dynon engine monitoring. When I fill up now I rarely have to add over a quarter-gallon more or less than the Dynon tells me that I have used.
Also, we have discussed the uneven draw from the tanks in earlier threads. I always fly with both inner tanks or both outer tanks open so that I can’t forget to switch tanks. My tanks may drain unevenly because my autopilot uses the ailerons to steer the plane, which means the wings are not always level. Frankly I won’t worry about this unless I’m low on fuel because if one tank empties the plane should just draw from the other one. However, I have never been really low on fuel and the tanks have never had more than a 4-gallon difference to see what would happen.
Les
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Gary Gower
Sent: Wednesday, July 01, 2009 10:22 AM
Hello Dan,
Saludos
Gary Gower
--> Zenith701801-List message posted by: Dan Wilde <dwilde(at)clearwire.net>
on for takeoff.
Dan Wilde
> Reguards. Dave
>&nNavigator?Zenith701801-List" target=_blank>http://www.matronics.com/Navig======================== Navigator Photoshare, and href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List Web Forums! href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ===========
bobkat
Joined: 07 Sep 2008 Posts: 143 Location: Bismarck, ND
Posted: Mon Jul 06, 2009 4:39 am Post subject: 701 fuel system design |
Yes, I'd sure recommend the digital fuel flow sensor on the Dynon. When it tells you that you have say, 5.7 gallons on one tank and 4.3 in the other, it is right on! Always within a tenth of a gallon or so.
Actually I found my 10 gallon tanks hold close to 11, so when I calibrated it, I put a gallon in them and then 'told' it that it was empty, etc. So I have 1 - 2 gallons more than the gauges tell me. A bit of a fudge factor.
Like Les, I'd highly recommend any fuel flow meter. My neighbor has another make on his RV-8 but I don't recll the make or mode.
In the rare instance when you start to get low with a few gallons in a tank, it will flash and yell at you to remind you to fuel up. It does everything to alert you short of a hand popping out of the Dynon and slapping you on the cheek! Maybe Les's autopilot grabs the stick from the pilot and flies to the nearest airport on the GPS database! Hah!
jetboy
